-   -   Horse Power Estimates? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/329530-horse-power-estimates.html)
moochie 02-09-2007 09:59 AM
With this weather, and Salt on the roads all I can do is admire my recently purchased 1981, 930 as it sits in the garage.
I was wondering how much HP this thing has?
I read that the Euro cars were 300 hp from the factory.
My car has a stainless header/exhaust system. (sounds mean). Also has the 1 bar boost spring.
What would those mods result in as far as Hp is concerned?
Also what should the boost be set at for my "Spirited" weekend driving? I've got a mechanical boost guage, and the little key to make adjustments.
Thanks!
im4duke 02-09-2007 10:43 AM
By gauge do you mean the one in the clock location, right of the tach? If yes and it has the little triangular key recess in the center, it is a gauge and only a gauge. It indicates boost pressure, but does not control it. The orange needle should move with the regular needle and sit at the highest pressure level reached, until reset with the key.
Anyhow, sounds like a fun car. Post some pics. Someone else can chime in with a guess on power.
moochie 02-09-2007 10:50 AM
Yep, sounds like they took out the clock. Thanks for clarifying the guage for me. I was wondering why the orange needle was so low. I thought it was some sort of Red Line, like a Tach.
http://i106.photobucket.com/albums/m...Picture001.jpg
http://i106.photobucket.com/albums/m...6-R1-14-15.jpg http://i106.photobucket.com/albums/m...8_565x421_.jpg
im4duke 02-09-2007 10:59 AM
Nice looking car. Looks familiar...
http://forums.pelicanparts.com/uploa...1171051132.jpg
Here's my boost gauge. I had just set the telltale to 1.1 bar because it was actually holding the other needle back.
http://forums.pelicanparts.com/uploa...1171051144.jpg
Craig 930 RS 02-09-2007 11:54 AM
Don't mean to sound like a JA, but you might want to learn a bit more about your car - for your own good - especially before making adjsutments to critical items in the future. Off-season is a great time to do so! Nice car. Cheers,
moochie 02-09-2007 11:55 AM
That's what I'm trying to do.
I have not even been able to drive the car yet due to the weather. All I can do is buy, & read books and try to learn all I can.
RarlyL8 02-09-2007 12:45 PM
Beautiful car.
A 1.0 bar spring is generally not recommended for use with a stock intercooler due to the possibility of detonation. An aftermarket intercooler should be your first upgrade.
Keep an eye on that VDO tattletail boost gauge. In my opinion they are junk. The tattletail needle can be stiff, binding up the boost needle, and eventually will break (like mine did).
Les Paul 02-09-2007 02:00 PM
What that red needle is supposed to do is tell you where your boost peaks. So don't set it tight or as Rarly says it would screw the boost needle up too.
Craig 930 RS 02-09-2007 02:40 PM
Problem is AFAIK you can't set it at all - NHS tolds me I need to send my VDO tell-tale in for repair and calibrating - it is too loose.
moochie 02-09-2007 03:27 PM
I guess I should say the reason I'm curious abot the Horse power on the car is that since I'm unable to drive the dang thing(it's just kill'in me), I've been thinking back to cars I've owned in the past,... trying to get an idea of what this car will be like. I'm figgering the Exhaust is probably worth about 20 hp or so. So I can guesstimate I'm about 320 hp plus whatever a 1 bar spring gives me. Problem is I have not read anywhere about what the spring actually means performance wise.
I'm not looking to go nuts with upgrades and create a modified monster. I want a fun driver. I kinda figured an upgraded intercooler was gonna be something to look into. In fact I've been reading up on those already.
Thanks for all the input :)
RarlyL8 02-09-2007 04:26 PM
If your engine is a bone stock '81 (300HP) Euro with headers and 1.0bar of boost my guess would be a peaky 330-340HP at the crank. The reason I say that is because the stock turbo and stock intercooler are holding back the potential gains of the headers and boost spring.
A new aftermarket turbo and intercooler would really wake your car up, possibly another 30HP worth.
DDDD 02-09-2007 04:47 PM
Don't spend too much time at these websites if you don't want to go nuts with upgrades and create a monster. Because soon enough you will find yourself spending every spare moment analysing all the naughty things you can do to make your car go faster. I know I do.
moochie 02-09-2007 05:13 PM
Thanks RarlyL8,
That's what I was wanting to know. A new IC is in the plan. The car already has the boost spring, so I ought to get the IC to be safe.
I figured things like an upgraded turbo would be done on an as needed basis. Ofcourse I bet a lot of people start out thinking like that, and before ya know it they've built a fire breathing beast :)
DRV2FST 02-11-2007 10:33 AM
Nice Ride
I see we have similar taste in cars. Mine is an 85.
Keep the mods to a minimum for a year. Learn the car and how to drive it. Take it to the track (where this photo was taken) and see what it can do in a relatavily safe environment.
When you are ready for mods start with the bolt-ons (InterCooler, Turbo, ...) and work towards insanity from there. If you ever drop the engine, you will eventually spend more on upgrades than you spent to buy the car. But once you are truely hooked on these cars there is not much choice.
You will soon be an addict. There is no 12 step program for this one. If you care about keeping your wife and/or your banker happy then sell the car now before you drive it. If not, welcome to the club. Just keep telling yourself it is cheaper than a needle.
http://forums.pelicanparts.com/uploa...1171221913.jpg
carmad 02-12-2007 05:57 AM
Initially, I would spend my money on suspension upgrades, replace all bushings,etc, get it to handle, and spend some time on the track learning how to drive the car. Get some better brake pads as well.
Then I would start on the slippery slope of power upgrades, either go back to a stock spring or make the intercooler the priority buy, it will be cheap insurance. Also make sure you have your AFR's where they need to be, again cheap insurance.
moochie 02-12-2007 06:31 AM
Whats' an AFR?
DRV2FST 02-12-2007 06:53 AM
Air Fuel Ratio
turbobrat930 02-12-2007 06:56 AM
Whats' an AFR?
AFR = air/fuel ratio...VERY, VERY important in these or any motors
Another plug for either a aftermarket I/C ( intercooler) or go back to the stock spring for now.
Garen 02-12-2007 08:46 AM
My $0.02: Get the stock spring, drive and enjoy the car. That way, you know you won't be stressing the engine too much, and also get to know the car. Do a Porsche Club Drivers Education or two, and see if it's your thing. A little more time with the car will be the best way to plan out future mods if any. Any well-instructed track time in a 930 can do wonders for helping you keep the car on the road during spirited drives. These cars aren't known for being kind to driver errors.
An intercooler upgrade is money well spent, and so is a newer turbo, suspension parts, brakes, etc etc...
Beautiful car, by the way.
911Velocity 02-14-2007 12:24 PM
Thanks RarlyL8,
Good luck with your new car, it looks great. As others here have said be careful with mods. They are addicting as is speed and handling. It is the proverbial snowball going down the mountain, it just keeps getting bigger and going faster till it hits the bottom then BOOM. But what a ride!!!
Regards,
GaryR 02-14-2007 02:36 PM
Re: Nice Ride
Ok, let's get our elbow off the windowsill shall we...
:D
DRV2FST 02-14-2007 03:27 PM
Thanks for the driving tip. elbow resting on door=bad form, Got it.
SCHNELE 02-19-2007 06:05 PM
Here is the number to the PUSHERMAN I know it offhand 913-310-9927
here is the link
http://www.imagineauto.com
Why wait get it ready for spring driving, C2 Intercooler or B&B, suspension bushings, K27HFS turbo, 1 bar spring, assuming Euro headers you are good to go if not you will kick yourself for waiting. Stock is like sex with 5 condoms on if you want to let Jimmy loose perform the above and strap in enjoy the mind blowing orgy.
930turbo 02-19-2007 06:12 PM
For quantification, the additional .2 bar is worth about 19HP. Here's a link if you want to fiddle with the potential gains:
http://www.turbofast.com.au/tfcalc.html
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
