930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Question rrrrrrrr noise when let clutch out?
is this signs that a rubber ceter clutch is gonna grenade? does the throwout bearings make noise on thier way out also?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-18-2007, 09:49 AM
Its tough to say but it could be like you suggested your throwout bearing but it could also be your mainshaft bearings getting a little tired.
If you push the clutch pedal to the floor the noise should stop and as you let the clutch out ( In neutral) you should start to hear the noise. chances are that its the throwout bearing though.
Old 02-19-2007, 10:15 AM
Forced Induction Junkie
WERK I's Avatar
could be the pilot bearing in the flywheel going. Mine made a groan when the clutch was being released. Pilot bearing was shot.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-19-2007, 11:09 AM
my release bearing squeaked intermittently, then right before it failed it began squeaking all the time, exploded about 75 miles later!
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 02-19-2007, 11:57 AM
h20cooled7's Avatar
only does when its in gear and you let the clutch out at the right spot. when i press it to the floor it will stop . I'll get a slight shudder out of the drivetrain. the car shifts fine and wthe week b4 i adjust the clutch to spec. the clutch will will grab at the very top of the pedal . I was told this is normal from another 911 owner. i guess ill start saving for a clutch over haul.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-19-2007, 12:31 PM
A fellow Pelacanite
NathanUK's Avatar
I'm sorry but it sounds like the tranny to me. The good news is that I am not an expert...
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 02-19-2007, 02:26 PM
h20cooled7's Avatar
ok talked with my friend a retired Porsche mechanic (Jim Long)in the Warrenton ,Culpepper VA area. Great all around guy and a wealth of info. He says the clutch is probably over adjusted. I adjusted the back fine ,but didnt set up the pedals right . So hopefully i can readjust the clutch pedal and everything will be ok. I'll let you know how it turns out and if im still gonna make that trip to clutchville. hope not. thanks for all your help in my downward spiral.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-19-2007, 02:55 PM
930turbo's Avatar
Try to picture the speed of the components related to a gear change, then associate the noise/speed with the component. Does the sound match the engine speed, the input shaft speed or the difference between the two? A pilot bearing will usually make noise as the clutch disc slows to rest when shifting into gear when stationary (difference between the two). A throw-out bearing noise will match engine speed. A mainshaft bearing noise will match the speed of the selected gear (i.e. upshift/downshift)
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 02-19-2007, 06:00 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
