935TURBO's Avatar
Question PORSCHE 930 / CAYENNE...rear calipers
Hi everybody....
Does someone know if the Cayenne calipers and discs can be ok for 930 / 88 rear arms....?
Thanks.......
Serge
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 02-19-2007, 09:43 PM
That is a lot of unneccessary brake and add to your unsprung weight. The Big Reds are AMAZING, I have them on my car, those above is pure overkill even if they do fit.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 02-20-2007, 07:15 AM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
ive read the 930 brakes are straight off a 917 ,enuff said
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-20-2007, 05:13 PM
Me like track days
Craig 930 RS's Avatar
I'd surmise (guess) that the Cayenne calipers woul flow more fluid than the stockers....
Depends on what you have on front -
"Why bother" comes to mind...
Why not go with a proven setup?
930 brakes are fairly related to the 917, but are not the same.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-21-2007, 01:37 PM
935TURBO's Avatar
Hi guys....
My problem is the following one......
930 Big Red 996 TT rear adapters....?
So....i need some help......
Old 02-21-2007, 01:41 PM
Me like track days
You need to contact :
http://www.instant-g.com/
Old 02-21-2007, 01:47 PM
935TURBO's Avatar
Yes...I did it and ask for the adapters....but I got no reply since 2 weeks now.....!...?
Old 02-21-2007, 01:56 PM
Send a message via Yahoo to Lukesportsman
Its a small operation and has a good reputation. Maybe try again and give him a little more time. I responded on the other thread too in that do you think you have NON 930 trailing arm adapters? Maybe contact the original vendor and see if they carry both, possibly swapped by accident.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 02-21-2007, 02:57 PM
935TURBO's Avatar
"Maybe contact the original vendor and see if they carry both, possibly swapped by accident."
Unfortunatly...no...they didn't make any mistake....and they didn't understand why it doesn't work....probably 930/1988 rear arms are different...?....
At the begining I did that upgrade because I found the 930 calipers/discs not enough efficient....and now...rear are not enough because as you probably know, 930's front breaks are often "blocking" when you brake hard....and there's no way to balance front/rear...I tried to limit front....and the results are a bit better...but not as much to have a good front/rear balance....(sorry if my technical language is not completely correct...but I hope you'll understand what I mean...)
Serge
Old 02-21-2007, 03:25 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
