JakeTheSnake's Avatar
Type/Grade oil recommendation needed
Can anyone tell me what grade of engine oil I should use a 88 Turbo. It has 64K miles and is a 3.3L H6. Any help would be greatly appreciated.
Thanks,
Jake
Big Jake
Porsche 996
I've been known to take apart a 996 or two.
Old 02-23-2007, 12:00 PM
resident samsquamch
sand_man's Avatar
I use to run Castrol 20W-50 (dino) in mine, but have since switched to Mobil Delvac 15W-40 (also dino). I also used Shell Rotella "T" 15w-40 with good results. Be prepared as you'll get a lot of different answers on the "oil debate".
-jeff
Old 02-23-2007, 12:09 PM
R Wilco's Avatar
I'd always used Castrol. After a recent rebuild since there were no leaks I went to Mobil 1 5-50. The car runs 20-30F cooler than ever before. This is on a relatively modded 76 turbo.
Old 02-23-2007, 12:39 PM
WydRyd's Avatar
Mobil 1 5W-50 here
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 02-23-2007, 12:51 PM
Mobil1 15/50. Anyone have any experience with AMSOIL products???
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 02-23-2007, 07:47 PM
Thanks again for the assistance,
Cheers,
Big Jake
Porsche 996
Old 02-23-2007, 09:36 PM
Cymru am Byth
carmad's Avatar
Mobil 1 15/50
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 02-24-2007, 06:12 AM
A fellow Pelacanite
NathanUK's Avatar
M1 15/50 here too.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 02-24-2007, 08:11 AM
Me like track days
Craig 930 RS's Avatar
15/50 M1 here also. But it had M1 since the rebuild, so no leaks.
Jake, did you know the M1 in a car that has seen only non synthetic can more often than not spring some leaks?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-24-2007, 02:53 PM
I disagree. I have switched over 12 cars that I have owned from mineral to Mobil 1, and I have never ever experienced leaks from the switch: Toyota Land Cruiser, Volvo's, BMW's, Jeep GC's, 3 911's, 1 930, even my Range Rover!. I am not saying it doesn't occur, I've just never seen it. The mileage of these cars at the time of the switch ranged from 10k to 120k. I switched the Range Rover at 70k, and it now has 165k no additonal or increase in the existing leaks!!
I've rebuilt engines, ran them on mineral for 10k then switched, no leaks.
I'm sure it happens, but if it were more often than not, I think I would have experienced it, as I have done this in a variety of cars since 1987.
Tim
1986 930
Old 02-24-2007, 07:17 PM
I use Mobil 15/50.
Interestingly, Mobil and Amsoil are two of the few oils left that put zinc in their oil, which is totally vital in Porsche air cooled engines. In fact, they have almost identical amounts. Amsoil is as good as any oil, but I still go with what Porsche uses internally.
If Mobil gets rid of their zinc levels, I will likely switch to Amsoil, if they still use the zinc. Or Redline or Royal Purple, if they still use zinc.
I did just look into getting octane boost for hot summer days, and Amsoil has a product which works better than most in some reviews I found, it's worth about 2.25 octane points, so I think I'll try that this summer. Easier than mixing toulene, I think.
Old 02-24-2007, 07:48 PM
D - Have you looked at Amsoil's 20/50 racing?
Tim
1986 930
Old 02-24-2007, 07:53 PM
No, I just saw that they run the same zinc levels as Mobil 1.
I personally have no experience with Amsoil but have heard only positive things about them. If you change the oil after 3,000 miles, I would think Amsoil is just fine.
Old 02-24-2007, 07:58 PM
I found the link about the zinc.
http://www.lnengineering.com/oil.html
Old 02-24-2007, 08:17 PM
Me like track days
It is a well-known issue with 911/930 engines, TimC.
Old 02-24-2007, 09:13 PM
Craig, I've heard it, but in 20yrs of playing with these cars, and working on friends 911's, which included many conversions over to Mobil 1, I've never experienced this. Maybe I've just been lucky....
Tim.
Tim
1986 930
Old 02-25-2007, 03:12 PM
Forced Induction Junkie
WERK I's Avatar
Castrol Syntec Blend 20-50W, changed every 4K or 6 months whichever comes first.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-26-2007, 07:02 AM
I just ordered Amsoil Series 2000 SAE 20W-50 Synthetic Racing Oil. They say that you can extend 3x manufacturer's recommended intervals, although right now I'd never do that, no technical reason just uncomfortable. I talked to their technical dept, told them it was for a 930, mentioned the air/oil cooled engine and turbo as opposed to water cooled, and it did not seem to matter. I'd really like to know how they base their intervals...I'll get it analyzed after 3k and possibly go 5k.
tim
Tim
1986 930
Old 02-26-2007, 02:23 PM
Me like track days
Uhm, yeah......
Old 02-26-2007, 02:44 PM
Please change your oil after 3,000 miles. I am asking you nicely.
I don't care if they say you can go to the moon and back.
Your oil might not break down structurally at the microscopic level, but it will still get DIRTY after 3,000 miles. It is not the oil itself which is a concern, it is all the CRAP that will end up in your oil from burning gas through your engine. Twice as much if you have a turbo.
Old 02-26-2007, 04:39 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
