DRV2FST's Avatar
Engine Rebuild EFI results
It is still a 3.3 but with JE Pistons. Tec3r EFI with sequential injection running 72 lb injectors. It has a Garrett Turbo Charger and a Borla Muffler. All work done by Pat Williams Racing. I had some work done by other shops before but none of that work held up. Pat redid everything.
Questions, Comments?
Kirk
Crashed: Silver 1992 Turbo S2
Sold: '86 930 minor mods; '94 3.6 Turbo; '85 Euro 930 (3.2 Intake, Tec3r EFI, TwinPlug, Garrett Turbo, JE 8.1 Pistons, 505 rwhp)
Old 02-26-2007, 06:25 AM
Any idea why there is a (relatively) huge dip in AFR at ~5600 rpm?
Are you using 3.2 intake? And I'm curious about your injector duty cycle (I'm using 52lb ones and am running out).
thanks.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 02-26-2007, 06:31 AM
DRV2FST's Avatar
I don't have the EFI MAP in my possesion just yet, so I don't know why the AFR behaves that way. I am using the 3.2 intake. I'll run a datalog later today and gather some information about injector duty cycle.
Kirk
Old 02-26-2007, 06:33 AM
The numbers look really good especially at 0.85 bar!
Would be interested in any other details as well, for example: which Garrett do you have? A/R and Trim? How about the cams?
TIA
Olli Selander
1989 930 - 3.5l - M48 - G64/51
Old 02-26-2007, 07:08 AM
David's Avatar
Those numbers are huge for 0.85 bar and the curve looks really smooth for a monster turbo. What are the full specs?
2014 Cayman S
2011 Cayenne Turbo
Old 02-26-2007, 07:35 AM
Crotchety Old Bastard
RarlyL8's Avatar
Wow, nice job. Get that A/F curve straightened out and there is even more free power.
Old 02-26-2007, 07:52 AM
7.0:1 > 11.3:1 > 7.0:1
A little over 500 at the wheels at .85 Bar. So this would only be mid 500 at the FW.
Rather measly results.
Joking aside, do you have an explanation for the rapid drop in torque above 6000. Stock cams?
So what would 1.0 bar do? or are we not going there.
Sounds like similar performance to Mikes turbo.
David (125 shifter), was your torque curve still flat above 6000?
Jim
Old 02-26-2007, 08:40 AM
DRV2FST's Avatar
More Specs to answer some questions:
Euro SC Twin Plug Heads
Large Intake valves
Webb cams 964S (05-302)
I have a 1.0 bar spring in the WG but measured at the manifold it is only getting to .85. Measured at the brake booster it reads higher for some reason.
I certainly could use some more tuning on the A/F curve. I got tired of waiting on the car and took it before they got it fine tuned. I'll drop it back off to Pat in a month or so when I go on vacation.
Kirk
Old 02-26-2007, 09:55 AM
David's Avatar
Where is the MAP sensor connected? I wonder if it's not getting a true signal?
Either way, that's great output for your setup.
My curves look very similar to those just lower . At 0.7 bar, my peak hp is 390 and peak torque is 340. We ran it up to 7000 rpm, but I think peak hp was about 6000 just like DRV2FST's curve.
2014 Cayman S
2011 Cayenne Turbo
Old 02-26-2007, 11:40 AM
DRV2FST's Avatar
Map Sensor
Here are some photos of the engine bay from slightly different angles.
I guess this is the MAP sensor. Am I correct?
Kirk
Old 02-26-2007, 01:32 PM
WydRyd's Avatar
Very nice indeed! Congrats and enjoy!
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 02-26-2007, 02:19 PM
Yes, the one in the bottom picture is the MAP sensor. Where does the hose connect to?
Old 02-26-2007, 03:05 PM
DRV2FST's Avatar
Which hose?
Kirk
Old 02-26-2007, 03:09 PM
Originally posted by DRV2FST
Which hose?
The hose from the MAP sensor
Old 02-26-2007, 03:17 PM
DRV2FST's Avatar
To the bottom of the throttle body. It is the middle one in this photo.
Kirk
Old 02-26-2007, 03:32 PM
DRV2FST's Avatar
By the way, it just passed emissions without a CAT. I'll post the story in the general 911 technical forum.
Kirk
Old 02-26-2007, 03:34 PM
Hey, DRV2FST, I like your project and I sent you a private message about it.
Old 02-26-2007, 03:55 PM
DRV2FST's Avatar
thanks, PM replied
Kirk
Old 02-26-2007, 04:12 PM
beepbeep's Avatar
Great results! You/your builder did everything "right".
- Garrett turbo (you never mentioned which one? I presume GT35R or GT40R) and no KKK stuff
- EFI and no CIS
- Carrera intake and not sub-optimal CIS intake
- Bigger IC
- Twin plugs
- JE pistons.
- Correctly sized injectors from scratch
Also, depending on where you take your boost reading from, you might get higher results before intercooler compared to plenum. Your intercooler might be a bit too small. I guess that your internal boost gauge is fed off the brake-booster line and that dyno papers used MAP-sensor, right?
AFR curve is conservative, with rich readings where V/E is supposed to be high. It would be informative to see VE table from your EFI. I believe you could pick some extra torque in the area where AFR's are low by leaning them a tad but it all depends on VE at that revs. If car is breathing "well" where AFR's are in 10's then Pat Williams probably kept it rich to keep it safe which is a sign of a pro. It's better to have a bullet-proof engine with slightly less torque at lower revs than one with hole in a piston
Thank you for your time,
Old 02-26-2007, 11:39 PM
David's Avatar
Since there's air flow through the throttle body where the MAP sensor is reading, it will read a lower pressure than in the manifold. I'd trust the boost gauge since it's getting pressure from the side of the manifold where there's less flow.
Even at 1.0 bar, it's really excellent results.
2014 Cayman S
2011 Cayenne Turbo
Old 02-27-2007, 03:58 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
