1979 930 electrical question
Trying to learn how my 1979 930 works (or doesn't) compared to a '88 930 I recently sold. I have never owned this early a model so wonder what preceded later 1988 ECU/DME controls. I am having a stalling problem and trying to find the gremlin. Have changed Fuel pump relays. Also: Is it common for 1979 930s to have fuel pumps operating with key in ON position before activating starter? Any input sincerely appreciated.
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
On the back of the air/fuel metering assembly, there is a green connector which is most likely disconnected, this will make the pumps go on as soon as the key is in the on position. When it is connected, the fuel pumps are only live when the engine is cranking or running.
1987 930 1956 Chevy 3100 2009 Subaru Forester 2003 KX250 X2(I like my toys!!) Last edited by mark '87 930; 02-27-2007 at 02:26 PM.. |
930s rule the wasteland
my 80 they sound like they run with key on or when cranking. my fuel accumulator is taking a dump and doesnt want to restart when it sits for 5 mins. im gonna swap out fuel filter and accumulator this weekend. i'll let you know how it turns out
pete
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
Thread Tools | |
Rate This Thread | |
