Crotchety Old Bastard
Because you have just purchased this car and do not know much about how it was (or was not) built it would be wise to turn your boost controller off.
Explore your modifications and get some A/F ratio data and then start bumping up the boost as your system allows. You can melt a piston fast if your engine is not set up to handle the additional boost.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Me like track days
Makes you wonder what kind of treatment the car received prior to this purchase.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
You are in serious danger of destroying your engine if you have messed with the boost already. You should not turn the knob ANY further than what it was set at, and even then you don't know if the prior owner was a nutcase or if he cranked the boost to sell the car, or what.
You need to actually have a read out of the Air to Fuel ratio your CIS is running to know if you can safely run ANY level of boost. You can adjust all this, of course, to a degree, but basically when on boost your AFR should never get above 12.3 at the most lean spot in your rev range, and it should stay around 12.0 if possible. Unless you are ready to do this all yourself, turn the knob down and go to a mechanic. Do not go out on the highway in 4th gear and start driving around randomly tuning it. Don't do anything but check the AFR and tune it correctly for a given boost level, and don't try it yourself if you are not experienced in this matter. You need a Porsche specialist mechanic that you can trust to drive your car and tune it with a real AFR meter and maybe a dyno. My boost knob will turn up to 2.2 bars. That would burn up my engine in minutes. You have no idea how quickly you are going to ruin your engine if you just start turning that knob. They call it the knob of death for a reason. And most mechanics will stick it under the seat or somewhere else so a guy won't mess with it. Last edited by DDDD; 03-08-2007 at 09:36 PM.. |
Me like track days
Definitely.
Adjustable boost appeals to the "I can adjust my car and do upgrades" side of the brain - aside from that, and the fact that it can make initial & final adjustments to incremental boost increases easier - it is an idiotic device. Think about it: WHY would you want one? Something else: Your CIS system goes full rich at a relatively low boost pressure. When there is enough air volume to lift the CIS metering plate fully upwards, you *have then achieved maximum fueling* That is it baby.....there ain't no more.
7.0:1 > 11.3:1 > 7.0:1
The nuts n bolts of the problems are: air/fuel ratio correction to avoid a lean mixture as seen with stock CIS above .8 bar boost, ensuring ignition timing is correct, fuel octane adequate to avoid detonation. The boost regulator indicates that your car has been run at elevated boost so perhaps it has sufficient upgrades, or not. My opinion is you should spend a little time to investigate your upgrades prior to going foot to the floor. Heck, bone stock 930s should have timing and AFRs inspected. You never know what has taken place with previous owners, my own 930 being a perfect example. Good to hear you are pleased with your car. As Craig said, try to include some pictures of the car itself. We never see enough! Jim 79 930 |
Geeze, a guy types up a reply and comes back sounding like an echo!
If I had my car for one month I wouldn't think I am an expert already. You damn sure can go out on a highway and in 4th gear peg it to see what your boost is. I've had a 911 Turbo for 22 years, I think I know what you can and can't do.
Me like track days
Right on Jim and 4D - and, lacking a description of the possible modifications, a picutre or five may help us help you, H2.
These are very, very expensive to fix when they go KABLAMMO in the course of but 5 seconds...
930s rule the wasteland
Okay i will tke pics this weekend and set it to 12 psi . Man getting my _ss kicked on this 1. I thought stock motors could handle 1 bar? I,ll bump the pics i psoted awhile back.
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
There are ways for a mechanic to increase your boost with more fuel through the CIS and also additional fuel enrichment, and so on, and your car might even have that, but you need to find out. |
how can i tell if i have the larger fuel head?
A bone stock 930 can handle 1.0bar IF the intercooler has been changed out to an oversized unit AND the octane of the fuel is sufficient. You also need a reliable boost gauge. The stock unit is not that accurate.
The deal is that you say that you don't know what you have so it is prudent to leave it at stock boost until you do know what you have. That's all. You don't need a modified or Euro fuel head to run 1.0bar of boost on a stock or slightly modified engine with a stock C/R. You need proper A/F ratios. (A euro head is black while a US head is silver in color). The stock fuel head will support 400HP so you have some room there.
Me like track days
Even at 1.0 bar with a big IC and appropriate octane - bad things can and do happen.
To get that proper AFR at 1.0 bar usually requires more fueling in some areas ie more accurate and approriate fueling - and, as Brian says, it's all a guess unil you measure your AFR -- AND definitely do make a 100% system check- consisting of timing, distributor function, and the aforementioned appropriate fueling. Yes, many times you will not need a different fuel head. The adj. WUR......man...I'm telling ya, it really makes a difference.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno Last edited by Craig 930 RS; 03-09-2007 at 09:01 AM.. |
adjusted boost control but makes no difference.
yes it does make a difference , if i cut it off it will limit it to one bar. im just gonna leave off, the car is a handfull to drive with it cranked.
A fellow Pelacanite
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Me like track days
I doubt that you do have the IA fuel head - the mods on your car look to be older, and the fuel head hasn't been around that long.
IA head has something to do with the metering slit opening width -
You probably experienced more wheelspin, and maybe your car also squatted on acceleration even more than usual, as well as dramatic forward weight changes when you came off the boost by backing off the throttle. Just a guess. You can always tune some of that boost back in, but you need to set the boost at one level and tune the AFR with an AFR meter around that specific level of boost, and after that don't touch the dial of death. If your car is handling different under more boost and you don't like it, you then have to consider bigger rear torsion bars, and revalving your rear shocks to match, or upgrading them. Unless you don't mind all the back and forth weight transfer. It sure increases the sensation of acceleration! |
the car is set up pretty tight. is there a procedure for centering the drivetrain when you install the engine?
Thread Tools | |
Rate This Thread | |
