GO DAWG GO's Avatar
Turbo Front Wheel Bearing Access
I was checking my 1987 front suspension a while back and had the front jacked up yanking and twisting. I was checking for any slop in the suspension and tie rods. I noticed that the right front wheel had a little extra play in the front wheel bearings. Figured I would replace the bearings and seal when I repacked them. Interesting enough, the dust cap is completely recessed in the adapter and not easily removed. I also noticed that it has a spot welded threaded bung or boss in the center. How do you guys remove the cap? I did a query on the net for a tool and didn't come up with one. I was thinking of making a puller out of C channel and a 8 MM stud and bolt to screw in the bung and pull it out... Like a VW oil pump puller for those of you who have seen one. Is there a tool available?
Bob
Old 03-06-2007, 12:38 PM
A fellow Pelacanite
NathanUK's Avatar
Slidehammer. Some guys made their own out of studding and a heavy weight.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-06-2007, 02:59 PM
You can rent(borrow) a slidehammer kit from Autozone for free. If you get a bolt size that fits in the cap, you can rig up the hammer to pull it out.
Old 03-06-2007, 04:27 PM
mark '87 930's Avatar
Do a search on the 911 forum, this has been discussed a few times as I discoverd as well. I did mine a little over a year ago and made my own tool for $8.
Help Removing rotors on 87 930
front wheel dust (bearing) cover removal
Wheel Bearing Dust Cover Removal
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 03-06-2007, 04:37 PM
GO DAWG GO's Avatar
Nathan, Doug and Mark,
I had no idea this has been a thorn for so long. I thought someone would say "Hey Bob there is a $10 tool for that" ..What does Porsche do? If that threaded bung has a history of coming off????I think when I do get them off I will drill a concentric hole and install a class 8 bolt with the threaded shank facing outboard and make a puller from C channel like I said earlier. The slidehammer is not a good method because it relies on a shock method which that bung and its attachment process has a history of failure.. I think I will design a puller and sell them.
Do you think they would sell for $10-15 if they worked? A thinner dust cap with a firm attachment device....Hummm! I bet VW makes a cheap dust cap that would fit and be modified? Thinking out loud!
Bob
1 bad 930
Old 03-07-2007, 06:17 AM
Bob, The tool I made was a puller type. It was basically a threaded rod with large washers and a steel plate. As I tightened the end nut onton the plate (supported by the lug nuts) the dust cap pops off.
1956 Chevy 3100
Old 03-07-2007, 06:23 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
