Twins are more fun!
JMA-RUF's Avatar
Question Turbo oil feed...
Anyone know whether there's a 4-way 1/8" NPT fitting that will fit where the oil pressure sender is at the back of the engine?
This is so I can tap two -3AN oil feeds for the two turbo's and one port for the oil pressure dummy light switch.
Solutions please?
James
Carrera TT
(3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's)
Old 03-06-2007, 11:11 PM
BoxxerSix's Avatar
You looking for a 3-way AN to male npt fitting, or 2-way any to male npt with female npt port for gauge??? There's a ton of options out there for your application.
I have to go pickup an Ultima right now in MA and won't be back until late tonight but tomorrow morning when I'm back at the shop I'll pull out my catalog and get you a part number/price. I believe it a 3-way an adaptor to npt, then just need an appropiate adaptor for the guage. Day Racing and Speedway have them if you're in a hurry to get the part. I believe they have an online catalog you can order from. I don't have anything right in front of me now to peek at for you but i know the fittings are available....
Adam Hennessy
Old 03-07-2007, 03:09 AM
i also have a bunch here..
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 03-07-2007, 06:46 AM
Twins are more fun!
JMA-RUF's Avatar
Thanks guys.
Or I can just use two 1/8" NPT 3-way adapters, right? One screws into the other and that'd provide the extra port for the second turbo?
James
Carrera TT
Old 03-07-2007, 12:05 PM
yup
Ben
Old 03-08-2007, 02:49 AM
Crotchety Old Bastard
RarlyL8's Avatar
Dumb question, but will the oil sender hole supply enough oil for 2 turbos? If so I need the same fittings.
Old 03-08-2007, 10:08 AM
WydRyd's Avatar
Sure does... Protomotive use that source for their twin setups too
Wonder if there's ONE fitting that is designed for such an application? i.e: has two ports for turbo oil feeds and the top port for the OEM pressure switch and the bottom port screws into the block?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 03-08-2007, 05:17 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
