-   -   May have solved stalling 930 problem... (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/334506-may-have-solved-stalling-930-problem.html)
e p slick 03-08-2007 02:08 PM
Previous owner had installed "secret" kill switch for fuel pumps. He ran ground wire to hidden switch burried in temperature control module housing between seats. Craftmanship was pretty dodgey and I expect that sloppy and aged connections intermitentently failed. I removed this lash up and also isolated two pump relay hot wires to separate fuse blocks. Finally rewired ground wires to a more substantial and secure connection. Imagine the problem has now been eliminated. Thanks to all for input and suggestions.
EPS
David 03-08-2007 02:53 PM
Congratulations, sound's like you're a little better at wiring problems than some of us (like me :D).
