Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
935TURBO's Avatar
EFI....again...?......
Hi everybody....
I'm back to you all to have your opinion about DTA fast DTA P-8pro and the complete EFI kit from Goingsuperfast.....?
Now I got all other parts...excepted EFI....I must make the right choice.....
Thanks,
Serge
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 03-10-2007, 01:35 PM
WydRyd's Avatar
Get the system your local tuner knows best! You can buy the best ECU on the market (e.g: MOTEC), but if your tuner hasn't had any experience tuning it, then it won't perform at it's optimum best.
Talk to a few local tuning houses and find out what they use/recommend and make up your mind then... unless of course you plan to install and tune the thing yourself? If that's the case, then buy whatever you desire
Personally, I'm about to take delivery of a Protomotive MAP Motronic ECU shortly (i.e: next week). It's a drop in replacement for my factory Motronic ECU and already comes calibrated for my engine specs (3.3L EFI with GT2 CAMs). The tune should be 98% accurate to get me up and going fast
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 03-10-2007, 02:43 PM
I have the DTA P8 in my car. I would also highly recomend that you buy locally if you can. It is REALLY hard for someone to diagnos why your car is running like ***** when they are 1/2 way around the world. Much easier to bring the car to them.
I think the DTA is a good unit. I have had a few problems with it but I think I would have those same problems with other systems as well. IOW, it is my lack of experience in tuning that has made it hard to tune.
Have fun
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-10-2007, 06:59 PM
magic930's Avatar
The DTA P8 is a good unit, I have one on my 930. Lots of features for the price and the software is easy to use. With any ECU the most difficult part is startup (at various engine temperatures) then idle, then cruising conditions at various loads. Wide Open throttle is the easiest part! I would consider using Autronic SM2 or Motec if I was doing it again but at the time price was better for the DTA. I did buy my crank pulley/sensor wheel from goingsuperfast, but if you are in France you should look for a local supplier for the DTA unit so support is easier.
This is the user forum for DTA. Read about peoples problems and solutions! (lots of european users on the forum)
http://dtaforum.psycode.com/
Old 03-10-2007, 07:29 PM
935TURBO's Avatar
Thanks for your first answers....
I didn't mention that I need an EFI with the ability to manage those following caracteristics.....
twin-plug ignition / 962 heads / 3.5 L / 7.5/1
twin-injectors/cylinder...because I got a 3.2 manifold with 2 injectors / pipe...
twin-turbo system
SC cams...
I would like to manage the twin-injectors depending of the rpm and of the loading of the engine...for exemple....
soft cruising....only one ijector working
hard cruising or racing position....both working with flow depending of the rpm....
Does DTA, MOTEC, ELECTROMOTIVE or any other able to do that...?
Old 03-10-2007, 11:20 PM
A fellow Pelacanite
NathanUK's Avatar
Ruf did it, not sure how.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-11-2007, 03:04 AM
David's Avatar
If you REALLY want to run 12 injectors, you may have to go with a high end Motec box like the M800.
2014 Cayman S
2011 Cayenne Turbo
Old 03-11-2007, 04:40 AM
7.0:1 > 11.3:1
The SDS EFI system I used can support two injectors per runner so they are staged to activate at a preprogrammed load point.
Jim
Old 03-11-2007, 07:19 AM
what? me worry?
TimT's Avatar
Haltech also supports staged injection. We built our 935 clone with ITBs and two injectors/barrel. The first set of injector fires when the engine is running normally. The second set of injectors starts to fire when the engine is in boost.
Haltech
Also try to buy the ECU locally..
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 03-11-2007, 07:55 AM
magic930's Avatar
The DTA P8 will run two injectors per cylinder, and will allow offset spark per cylinder for twin plug applications. It also has a few auxilary inputs and outputs which can be used for just about anything. I would suggest downloading the DTA P8 software (free) and poking around in it.
Old 03-11-2007, 09:00 AM
The motec M400, M600, M880 can all run two injectors per cylinder the difference will be batch firing on the m400 versus sequential firing on the M600 or M880. You may want to pm Geoffrey Ring the resident Motec guru on this board, he is gring here.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 03-12-2007, 01:35 PM
magic930's Avatar
DTA P8 will do sequential injectors as long as you have a cam sensor.
Old 03-12-2007, 01:56 PM
onboost's Avatar
[QUOTE]Originally posted by TimT
[B]Haltech also supports staged injection. We built our 935 clone with ITBs and two injectors/barrel. QUOTE]
I've seen that Rudner's Racing 935 clone @ Summit Point Club Race... somethings' done right cause that puppy hauls azzz!
Nice IC too..
P-
RGruppe #180
So many cars..so little time!!
Old 03-19-2007, 02:09 PM
WydRyd's Avatar
I've been told that RUF used the same Motronic ECU as what was used in the 3.2L TT 962 of that era (1985 I think). RUF just re-programmed it for their application. That's what I've heard
Merv
'89 911 Turbo Cab
Old 03-19-2007, 03:59 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
