930 EFI - Ignition question
Just got my 930 back from having the new EFI tuned at the local dyno. I admit that the car drives pretty much the same as it did before I EFI'd it.
The max TQ/HP that it was producing on the dyno is still below the factory figures for a stock 930 engine. I am a bit worried that there might be some other issue (Like cam timing). One thing I did notice was that there is a LOT of ignition advance now. There is 37deg at 3000rpm. I have checked the cam timing twice before, should I do it again? I am open to suggestions and ideas. Steve
2008 BMW 320i 2006 Mercedes ML320 2004 Mercedes ML270 cdi 1998 Porsche Boxter 1988 Porsche 930 Targa (sold) |
Curious, are you still running the factory intake manifold, or Carrera manifold?
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() |
what? me worry?
Something is not right...
but we also need more info regarding your engines set up
who are those guys? <<< ( Butch Cassidy and the Sundance Kid) Rent a GT3RS from us!! Call or e-mail. Transportation and Track support Rudtners Racing '69 911 GT-5 '75 914 GT-3 Authorised Haltech seller and installer Authorised Unichip installer BBS wheels Fikse wheels Redline motors oils Swepco 1500 hp chassis dyno |
Hi Steve,
Something must be wrong if you don't notice a difference with the EFI. My motor put out maybe 50 more hp with EFI. But I did change a few things at the same time. Is that 37 deg advance at cruise or WOT. At cruise I run about 44 degs and at WOT about 25 degs.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Thanks guys..
here is the setup I'll post a pic when I get home today. Goingsuperfast EFI Kit Wasted Spark EDIS system 55lb Siemens Low impedance Injectors 36-1 Trigger wheel Factory 930 Intake manifold - Billet Injector Blocks Factory Intercooler Factory Diverter Valve Innovate LC-1 Wideband EMS Stinger ECU K27-7200 Turbo Aftermarket Exhaust That 37deg is at cruise. I'll post the ignition map tonight.
What cams? Are you twin plugged or single?
Stock Cams Single Plugged Ford EDIS CoilPack 0.8 bar boost
Forced Induction Junkie
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I was a bit dissapointed whan I changed the 3DLZ for the K27-7200, I noticed a bit of an earlier spool but it missed the rush of the 3DLZ when it came on boost.
I have recently purchades a TIG welder and I would consider doing some fabrication and installing a GT35. Has anyone else reading this done this?
If I were you I would change the cams and build a big ass intercooler with you new tig welder.
Also what dyno are you using?
My 2 cents... 37 degree at cruise seems to be very high.
I think even the NA cars only runs 32-33 degree max?
87 930 K27HFS/B&B/Twin-Plug... Megasquirted ![]() |
What freekin Oil Leak?
If your HP/TQ values are truly below the factory specs with that setup, then I think you do have an issue.
Mike (mppickett ) has a spark table that advances his EDIS/Megasquirt ignition to as high as 36 degrees but only over a very short range during acceleration. You may already know this, but you cannot use the timing lights with the selectable advance on EDIS systems. This will give you a faulty reading. You have to set the light to zero degrees and then read the advance using the pulley markings.
Steve '79 930 US Last edited by TurboBert; 03-12-2007 at 08:29 AM.. |
Thread Tools | |
Rate This Thread | |
