Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Things never to do with old fuel pump !
Decided to "test" old front pump to see if it was as bad out of car . Well old pumps make great gas powered rocket motors from left over fuel fumes. That sucker went about five feet !!!
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 03-11-2007, 02:17 PM
Hey ya'll, watch this!
Brian Keith Smith
Competition Custom Paint
1983 930
My Track Videos
TEC3 EFI Conversion on 1983 930
Old 03-11-2007, 03:39 PM
930gt-40r's Avatar
How did it ignite- did the brushes/comutator spark make it happen?
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 03-13-2007, 06:49 PM
Crotchety Old Bastard
RarlyL8's Avatar
HAAA!
Guess you didn't know that the liquid fuel is used to cool the pump (and prevents combustion until air hits it). I'll bet you filled your drawers on that one!
Old 03-13-2007, 08:29 PM
A fellow Pelacanite
NathanUK's Avatar
When I read about how that pump works I was quite surprised. Is it possible for the pump not to be vented properly when replacing it ? BOOM
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-14-2007, 01:31 AM
All I know is don't try it ! I put in a sx pump in front and removed the rear pump installing a fuel pressure gauge sender unit where the rear pump was and put the gauge in dash. Now I can make sure I can go full boost with out lean issue due to lack of fuel .
1986 blk 930
2000 expedition
Old 03-14-2007, 02:59 AM
RarlyL8's Avatar
Steve - great idea on the pressure gauge. Any pictures or details on the parts used?
Old 03-14-2007, 05:25 AM
Randy Blaylock's Avatar
This pressure sender is an electric type? Or did you plumb a hose to the gauge? In that case, an isolator is highly recommended; http://www.longacreracing.com/instructions/inst.asp?instid=75
Bullet Racing #22 GT3 Cup
Old 03-14-2007, 06:30 AM
It is electric sender I bought a brass double female threaded 2' long nut and two brass plugs ( all 5/8 american thread ) and I tapped a metric thread in the plug and I drill and tapped the brass female fitting in the center for the sender unit. Used a good pipe lock/ thread sealent and put the cover back on. I do have a question, On the front pump cover. If I leave the cover off do those bolts hold the anti-sway bar in position ? I drove it around the block and with the cover off and it seems a little wierd it grabs all the road cracks and it never did it before .
1986 blk 930
2000 expedition
Old 03-14-2007, 09:52 AM
There should be some links that go between the rack and the pan, which on some cars also holds the sway bar. The cover just protects the underside of the car there and isn't absolutely necessary.
Old 03-14-2007, 10:51 AM
1986 blk 930
2000 expedition
Old 03-14-2007, 01:08 PM
Here is a picture of my secondary "pod" it now includes a fuel pressure gauge to match.The second picture is just gratuitous
1986 blk 930
2000 expedition
Old 03-14-2007, 03:08 PM
What's an sx pump? Just curious...
'77 S with '78 930 power and a few other things.
Old 03-14-2007, 03:57 PM
sx-performance.com is a aerospace company that 's buy product is high performance pumps. Instead of purchasing two $ 500.00 bosch pumps I purchased one $ 300.000 pump from them. It is a piece of art work !
1986 blk 930
2000 expedition
Old 03-15-2007, 02:52 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
