Poll: Turbo support bracket installed
Poll Options
mark '87 930's Avatar
Turbo support bracket on or off
I am curious as to how many of you run without the turbo support bracket?
I don't want to slot mine (I am installing a K27), but instead will get a second one machined and will use that one instead.
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 03-16-2007, 06:22 AM
I am about to do the K27 install as well. A recent search came up with a Porsche part number 930 123 921 05 that MAY be the proper bracket for the install. Can anyone with a PET confirm this?
I have also read that the bracket can be modified/cut/bent for correct alignment. Mark, if you get a second bracket to work with, let us know what you did to make everything fit.
96 BMW M3 Coupe
89 951
Peugeot moped
Old 03-17-2007, 05:25 AM
Crotchety Old Bastard
RarlyL8's Avatar
I am also using a K27-7200.
The bracket was cut and re-welded to fit correctly.
I have heard from a reputable aftermarket tuner that the bracket is not necessary if you use a muffler clamp to hold the exhaust system in place. In my application it's just not that big a deal to keep it on so I did.
Old 03-17-2007, 06:00 AM
Shortly after I posted this message, I got a PM regarding that part number. It is in fact the 'right' bracket for this turbo, it's also $176 here on Pelican.
The bracket is a simple piece of metal, so I am going to get someone to make me one, it will be under $50 to get made.
1956 Chevy 3100
Old 03-17-2007, 06:01 AM
David's Avatar
I added a small bracket off the turbo flange:
2014 Cayman S
2011 Cayenne Turbo
Old 03-18-2007, 05:53 AM
A fellow Pelacanite
NathanUK's Avatar
Nice, probably saved some weight too.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-18-2007, 08:03 AM
