Crotchety Old Bastard
RarlyL8's Avatar
Wanted: Dyno Graph of a STOCK 300HP Euro 930
Does anyone have a dyno graph of a stock 300HP Euro 930?
I'm looking for not only the HP and Torque graphs but also the A/F ratios that go with it.
Any help appreciated!
Old 03-21-2007, 08:34 PM
A fellow Pelacanite
NathanUK's Avatar
There is a engine dyno in my euro handbook for bhp & tq.
I made one up from it.
Hopefully someone has one with a AFR chart.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-21-2007, 11:23 PM
A fellow Pelacanite
NathanUK's Avatar
Does anyone have a chart with AFR ?
Old 03-24-2007, 04:37 AM
RarlyL8's Avatar
Thanks Nathan.
What would be ideal is a modern dyno run that shows HP, Torque, and A/F ratios to about 6500 RPM using a 300HP stock Euro 930.
As an alternate I could use LM-1 data from the same engine. What I am looking for is fuel system delivery data from a stock engine as a point of reference or baseline to compare to the tuning I have done.
Old 03-24-2007, 06:03 AM
A fellow Pelacanite
NathanUK's Avatar
Ah, I see what you are up to. I hope you get one.
Old 03-24-2007, 09:06 AM
Here is a dyno of my 3.0L ROW 930 motor. It is not quite what you asked for. The motor has a K27 turbo, a big intercooler and shorty headers and a 1 bar spring but only got 12 or 13 PSI of boost. It ran lean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-25-2007, 04:27 PM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
subscribing
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 03-25-2007, 05:09 PM
RarlyL8's Avatar
Ouch Dean, is that A/F curve/line correct?
I assume you have it under control now.
Thanks for posting. Once I find a stock 930 CIS graph I'll start looking for EFI graphs as well.
How about this:
ANYONE WITH A STOCK EURO 930 MEETING MY QUALIFICATIONS THAT IS WILLING TO DRIVE TO HUNTSVILLE GETS A FREE DYNO RUN ON ME.
Old 03-25-2007, 06:17 PM
Yes, that A/F ratio is correct. I did correct it by selling the CIS and going with EFI.
I also have an EFI dyno chart if you want.
Dean
Old 03-26-2007, 03:32 AM
RarlyL8's Avatar
I'd like to take a look at your EFI graph as well.
The above graph is CIS?
Is EFI the only change you made after the above dyno run?
Old 03-26-2007, 07:14 AM
The above dyno chart is CIS.
Here is the EFI one. The things I changed when I went to EFI were:
SC cams
Carrera manifold
Slightly bigger intercooler.
Port matched head for Carrera manifold.
Also the EFI chart is on a DynoDynamic dyno. Not a DynoJoke I mean Jet.
The guy who ran the dyno said that my motor put out the same hp but a hair less torque than a stock 996TT. Not bad for a 3.0l running 13 psi of boost. So what did I do? I turned the boost up to 18 psi when I got home.
Dean
Old 03-26-2007, 03:57 PM
