Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
onboost's Avatar
Additional Gauges
Anyone out there running additional gauges in thier car..
EGT, AFR, Intercooler temp in or out or both?..
Show pics...
RGruppe #180
So many cars..so little time!!
Old 03-22-2007, 01:46 PM
WydRyd's Avatar
I have a Davtron in/out Intercooler Gauge, which reads in Celcius.
I'd really like to get one of those new B6 EGT/AFR gauges
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 03-22-2007, 06:05 PM
onboost's Avatar
What's up Merv..
Do you know where I can see a picture of the Davtron or the B6 EGT/AFR Gauge?
RGruppe #180
Old 03-22-2007, 06:13 PM
WydRyd's Avatar
I guess do a search on Google
I'd take a pic of the Davtron gauge for you, but I don't have my car here with me today... driving the wife's Jeep for a couple days
The Intercooler gauge is the Davtron 308FD.
Merv
'89 911 Turbo Cab
Old 03-22-2007, 06:36 PM
KCPSG's Avatar
here is a pic of my AFR gauge from Innovate, part of the LC-1 kit
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 03-23-2007, 06:52 AM
Anyone have a DP motor sport LED boost gauge?
Old 03-23-2007, 07:03 AM
onboost's Avatar
Merv..
Found Davtron but could not locate the 308FD or the B6 EGT/AFR gauges. Niether is listed on thier site.
Phil,
Where can I get a look at the Innovate, LC-1 kit?
Also, Have you guys seen these? Nice but pricey
http://www.spatechnique.com/index.asp
Paul
RGruppe #180
Old 03-23-2007, 07:17 AM
KCPSG's Avatar
http://innovatemotorsports.com/products.php
If I had to do it over again...I would get the LM-1 w/the XD-16 gauge...close to the same price as the LC-1 w/the XD-16 gauge...but w/the LM-1 its much easier to record your logfiles...simply put you can do more w/the LM-1.
Phil
1998 BMW 328i
Old 03-23-2007, 07:21 AM
A fellow Pelacanite
NathanUK's Avatar
Andial or Powerhaus has pics of those Davitron gauges.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-24-2007, 06:04 AM
onboost's Avatar
Nathan,
I don't think they have pics on either website. Talked to Andial the other day and they do have them.
RGruppe #180
Old 03-24-2007, 06:10 AM
A fellow Pelacanite
NathanUK's Avatar
Old 03-24-2007, 09:12 AM
A fellow Pelacanite
NathanUK's Avatar
Replaces clock.
Old 03-24-2007, 09:15 AM
onboost's Avatar
Thanks for the screen shots Nathan..
But in my own defense.. it been a while since I went to the Andial site, and for some reason.. looks like they had a bit of redesign.
On the other, guess I had brain-fade and did not equate B-6 with "Blown Six".
Saw that gauge on thier site a couple of weeks ago.. interesting piece.. somewhat similar in function to the spatechnique gauges mentioned above, and roughly the same price point. May have to look into it.
RGruppe #180
Old 03-24-2007, 11:22 AM
A fellow Pelacanite
NathanUK's Avatar
I just seemed to remember that Andial sold them, just trying to help people.
Old 03-24-2007, 03:04 PM
7.0:1 > 11.3:1
I run two digital Fluke handheld dual input K thermocouple meters on a somewhat gnarly center console mount in front of the shifter. I monitor EGT, head, oil reservoir temp, and rotate between I/C in/out, rolling tire temp via optical thermocouple, brake pad temp, occasionally some other track diagnostics.
Had a SDS O2 narrow band meter mounted lower left of my tach but this is now defunct since running the wideband O2 which I read via my SDS programmer. Eventually I'll remove the programmer and switch the O2 back to dash read out. Also have a custom dash mounted knock sender readout.
A point to note: I find most of this measurement stuff is redundant after initial tests as very little changes. However it sure would be nice to find a COMPACT, ALL DIGITAL display with multiple readouts offering a few thermocouple inputs and O2. Did I mention compact and digital? No graphics BS.
Old 03-24-2007, 09:48 PM
That BlownSix 4in1 gauge is very neat! Busy...but very neat!
Yasin
Old 03-25-2007, 02:07 AM
onboost's Avatar
Nathan,
Again thanks for the input. I'm on a short timeline with this...so it looks like I'll be ordering the Andial/Davtron 308FD & the XD 16.
For my needs the B 6 gauge is way too busy.. and I already have a boost gauge with telltale.
My center console already has a VDO EGT gauge mounted, and a Camden Superchargers LED AFR. Its a huge square box thats velcroed to the console.. (been there for years, present when I bought the car).. there is also a slot for a CD holder which I don't need. Wll be remaking the center unit of the console to hold the new items.
RGruppe #180
Old 03-25-2007, 04:41 AM
A fellow Pelacanite
NathanUK's Avatar
I like the look of this DB-Blue with a DL-32. Then you pretty much have everything you would ever need. The XD-16 looks way too busy to me.
The DL-32 comes with a button you mount to turn datalogging on and off.
http://innovatemotorsports.com/products/MTS_grid.php
Old 03-25-2007, 08:45 AM
BlkBird's Avatar
The problem I found is where to install these pesky extra gauges. There just is not enough available space for the ones I like to have: voltmeter, A/F gauge and of course, the vacuum boost (Well who needs a clock anyway?).
As to the first two gauges, well, who needs the ashtray?
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 04-03-2007, 05:02 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
