jasebird's Avatar
Wheel spacing question... RUF WHEELS
I posted a question a few day's ago about tire sizes and now I have a new problem( well not a problem....). I am using a set of Ruf wheels off of my narrow body car on my new 930 and the fronts (17x8) looks like they sit way inside under the fenders(plenty of clearance but looks a little funny) they need to be spaced out a bit, has anyone ever used this wheel setup and if so what size spacers did you use? I am running a 215/ 45 /17 on the front. The back(17x9) looks pretty good but maybe could scoot out a bit as well, thanks for the help.
Old 03-26-2007, 09:23 PM
David's Avatar
What year is your car and do you have any spacers now?
Old 03-27-2007, 06:32 AM
jasebird's Avatar
The car is a 1982 turbo and the only spacers on it are the stock rear spacers.
Old 03-27-2007, 09:47 AM
David's Avatar
You can run pretty large spacers before you have to go to bolt on spacers. Just figure out how much you need to add and whether or not you'll have enough stud length. Then order spacers and studs if needed. Obviously bigger spacers are easy. I've never changed studs, so I can't comment on that without a closer look.
Old 03-27-2007, 10:54 AM
A fellow Pelacanite
NathanUK's Avatar
You shouldn't guess spacer size on the front (the rear doesn't matter), if you do you alter the geometry. You must fit the centre of the new wheels exactly where the centre of the stock wheels were using spacers.
Using proper hub adapters means you do not have to worry about stud lengths.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-27-2007, 01:46 PM
