Engine cut off
Under hard acceleartion at around 6-6,500 rpm and just before the rev limiter cuts in the engine cuts out and the electrics go dead. Give it a second or two, switch it off and back on and it goes fine. Has anyone any suggestions please what might be worth checking? It first started happening on a track day but it could be because I'm now driving a lot harder as I get used to the car.
It's an '84 930 with K27, sc cams., 1 bar boost spring, Haywood and Scott twin exhaust (similar to B&B headers I guess) and Zucz powerflow airbox.
Any help gratefully received guys.
Old 03-25-2007, 11:09 AM
ChrisBennet's Avatar
The overboost switch?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 03-26-2007, 03:31 AM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
Chris,
Glad to see you frequenting this forum ( bet you feel like you own one huh? LOL)
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 03-26-2007, 08:42 AM
Hi Chris
Thanks for your reply. I had that replaced last week, took it out for a drive this weekend and the same thing happened. What I can't undertand is why the elctrics go dead but it then restarts without any problems. Not really sure whether there are any other relays worth considering?
Old 03-26-2007, 12:47 PM
9dreizig's Avatar
Maybe a heat issue with the CDI box?? I didn't think there was a rev limiter on an 84 turbo??
"Todd"
Old 03-26-2007, 12:53 PM
Originally posted by jono450
Hi Chris
Stock boost is something like .8bar isn't it?
The stock overboost switch opens when it detects more then stock boost. I'm just picking a number out of the air but lets say it trips at 1.1bar. You've increased your boost by virtue of your 1 bar spring so now you are much closer to an overboost condition. Under boost you will experience short periods of boost greater than 1 bar even though your 1 bar spring "limits" boost to 1 bar.
A friend with a '91 911 Turbo when through this and ended up removing the 1 bar spring.
-Chris
'07 BMW 328i Coupe
Old 03-26-2007, 12:56 PM
9dreizig's Avatar
Chris I believe that the std overboost switch limits it to 1.3 bar if I"m not mistaken
"Todd"
Old 03-26-2007, 01:01 PM
Re: Engine cut off
What do you mean exactly by "the electrics go dead"?
Do your headlights go out?
Do the gauges go dead?
Or do you mean the ignition cuts out?
-Chris
'07 BMW 328i Coupe
Old 03-26-2007, 01:12 PM
Can't say for definite but from what I recall there's no ignition lights until I've turned it off and on again but the dials are still working. I'll need to check the next time I'm out which won't be for another couple of weeks because I'm off on vacation. I'll post back when I've been for another drive and found out for sure.
Thanks for the the replies so far.
Old 03-27-2007, 11:35 AM
Gotta Jibboo
BSiple's Avatar
Send a message via AIM to BSiple
Having just dealt with the overboost issue, I have heard anywhere from 1.3-1.4 bar boost is what kicks in the switch.
As there isn't much to go wrong with the switch, and its pretty easy to replace.
Bill
2003 996TT
1992 964 Turbo (sold) Holy crap are these expensive now!
1986 911 Cabriolet (sold)
I don't know why I do the hillbilly things I do.
Old 03-27-2007, 02:27 PM
9dreizig's Avatar
I don't want to hijack this thread but my buddy who is driving my car out west for me tells me that mine is cutting out at around .9 bar on the boost guage ( and I only have a 0.8 bar spring in it). I do have a k27-7200 turbo in it. When he eases off the throttle to a milder boost it runs fine. Any suggestions?
"Todd"
Old 03-27-2007, 02:52 PM
Gotta Jibboo
BSiple's Avatar
The first thing I would check is to make sure the WG is functioning properly. If it is, then go to Rennlist, and do a search for 'overboosting" in the 964 turbo forum. One of the members moved his overboost switch to a line off the intake to elimate boost spiking, and it cured his problem.
Bill
2003 996TT
Old 03-27-2007, 02:53 PM
