930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
what was the wire colors on the boos sensor?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-22-2007, 04:23 PM
2369488's Avatar
The boost sensor was white.
The wire to the over boost sensor/switch I believe was brown and while.
Old 04-22-2007, 07:02 PM
h20cooled7's Avatar
hey man im trying to hook the stock boost guage up, i found a brown and white trace wire my sensor has 2 connectors.the diagram shows only 1 connection at the sensor but which pin do i use on the sensor? the g or wk?
pete
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-23-2007, 05:26 PM
2369488's Avatar
sorry Pete my new sensor only had the one pin connector so I can't help you with this.
Old 04-24-2007, 07:15 PM
h20cooled7's Avatar
cool ill finger it out
thanks
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-25-2007, 12:33 PM
A fellow Pelacanite
NathanUK's Avatar
Make sure your IC is earthed well.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 04-27-2007, 11:20 AM
h20cooled7's Avatar
GOT IT BROWN W/WHITE STRIPE GOES TO G,WORKS LIKE A CHARM
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-27-2007, 12:41 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Just got home.. there is a ground for the IC? Maybe thats why i'm reading .3 Bar with the engine off..
Gary R.
Old 04-27-2007, 07:04 PM
h20cooled7's Avatar
The IC bolts to the engine and uses the engine as a path to ground check your main engine ground .looks like a smashed braided hose. a bad main ground can cause all kinds of electrical issues. I think if you lose your main ground it will ground thru the clutch cable,also not good
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-27-2007, 07:12 PM
GaryR's Avatar
Isn't the IC mounted using rubber isolators? I'll check Sunday, see if I can ground it and see if there is a change..
Gary R.
Old 04-27-2007, 07:20 PM
A fellow Pelacanite
NathanUK's Avatar
The stock IC should be grounded fine (providing the transmission earth trap to the body is in place).
An aftermaket IC is well isolated from heat from the engine. This means that you really need to actually earth the IC using a wire. I will earth my Kokeln.
Earth your stock one anyway.
Old 04-28-2007, 01:19 AM
