WydRyd's Avatar
Originally posted by speeed racr
The oil is leaking out of the air intake , up pipe compressor, and the hot housing on both turbos. There is a lot of oil collecting inside the turbo. any ideas??????
Like others have mentioned above, I also suspect you are having oil drain issues. You really need to run -10AN oil drain lines out of those turbo's. Least restriction, the better. If you have enough height in those turbo's, lose the scavenge pump and just run a drain line into the lowest point on the lower valve cover, OR, drain both turbo's back into the sump oil drain plug/point.
Alternatively, you can run an electric turbo scavenge pump made by Westech or Turbowerx or something, but electric pumps, whilst reliable and robust, DO eventually fail.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-06-2007, 06:34 PM
can't wait
Old 05-07-2007, 11:11 PM
I have tried a oil pump utilizing -10 lines from the turbos to the engine case with still the same problem of oil backing up in the turbos. I think the oil is not being allowed back into the case. I will try to route the return back to the oil tank. Thanks for everyones advise.
Old 05-08-2007, 01:14 AM
Send a message via Yahoo to Lukesportsman
My turbo's drain isn't even -10, so how do you guys adapt? Maybe its just the small size of my TT's, but do you think running lines larger than the most restrictive orifice offering any benefit? I planned dual -8AN lines to a "T" at the sump drain on the 3.2 case.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v803996TT
Old 05-09-2007, 07:11 PM
WydRyd's Avatar
Hmmm... as long as the drain point is lower than the oil exit passage on the turbo and there's no restrictions, then oil shouldn't be backing back up the turbo. That's bizarre!
As I said, I run a -4AN UNRESTRICTED line to my GT35R and I have no issues.
Merv
'89 911 Turbo Cab
Old 05-09-2007, 08:41 PM
VZ935's Avatar
Send a message via AIM to VZ935
I have seen it happen where the oil cannot get scavenged fast enough on a gravity feed . I have had that problem and have run the Powerhaus scavenge pump which is basically a VW oil pump.
I just dyno'd my 935 motor at Jerry Woods yesterday. Jerry has a real nice sump plate with two fittings on it for scavenging the oil. It is a beautiful billet piece . In my case of a twin turbo application it has two 3/4 inch scavenge lines. I have these two pics I took but unfortunately they don't show the sump plate . I would call Jerry and ask him about it. The motor made 720 hp at somewhat conservative boost with hybrid K27s and cleared the oil from the turbos no problem
This is the 3.6 twin I had in my GT1 R club car... It is hard to see in the photos but I gravity fed the turbo oil return into the lower valve covers with no problems
A bunch of old race cars
Old 05-11-2007, 12:16 AM
Banned
Speed racer, did you solve the oil scavange problem??? Candy.
Old 05-24-2007, 09:03 AM
Forced Induction Junkie
WERK I's Avatar
If the crankcase is pressurized, from normal or excessive blowby through the cylinders, the gravity feed will not work. Do you see vapors pushing out the oil tank with the cap is removed when the engine is running?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 05-24-2007, 01:01 PM
930gt-40r's Avatar
Im having the same problem right now with my 37R. I had to clock the turbo 90 degrees from the normal location via an elbow. But now the turbo sits so low on the motor that the oil runs into the turbo on shut-down when the scavange pump isnt spinning. I am running a -8 an line for the return and a -4 an for the feed, I am going to use a -10 and try to slove the problem before I rip the rest of my hair out.
Mmmmm..... a smoking exotic car FUN!!
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 05-24-2007, 08:02 PM
I have got rid of the of the old set up. I am running a -4 feed with a restrictor to a 5/8 high temp hose. The return goes straight to the valve cover as a gravity drain. But the turbos are still filling up with oil.
Anyone have a match and some gas?
Old 05-25-2007, 08:31 AM
930gt-40r's Avatar
Speed racer, I am going to run the -10 line like I said before. I have another idea that mabye you will like- 996 turbos use a anti drain back valve on the turbo inlets. Im going to get one and tap it for 1/8" npt so I could run a -4 line to and from it. Next time you go to mess around with your car, try starting it and shutting it off with a drain pan under the turbo and your return line off. You will see it dripping for about 20 minutes after shut down, since your scavange isnt running with the engine off, the oil gets to back up from the residual in the -4 line draining into the turbo. I get the check valve in a week, I will let you know if it solves my problem.
Kris @ Tech9
86' 930/GT-40R Sold
Old 05-25-2007, 12:59 PM
Banned
He also can use the 930 type "ball" check valve, this will take care of both lines, best, Candy.
Old 05-25-2007, 01:42 PM
My problem is the turbos are still filling up with oil while it is running and blowing out the intake and compressor to the intercooler.
Old 05-25-2007, 03:26 PM
WydRyd's Avatar
Sounds like stuffed turbo's to me... sorry to hear
Merv
'89 911 Turbo Cab
Old 05-25-2007, 11:19 PM
Banned
You can do this test, with the exhaust taken off, so you can see the turbine wheels, take off the drain lines,start the engine, with suitable means to catch the oil start the car, see how the oil flows out and check the turbine if it leaks oil thru them toward the exhaust side and the compressor side,(always keep an eye the oil level keeping adding oil as needed), if it still leaks oil thru the bearings, then you probably have a bad set of turbos, hope this helps. Candy.
Old 05-26-2007, 01:39 AM
930gt-40r's Avatar
speed racer, your problem is that your turbos are not high enough in the car to gravity feed them in those lower valve covers. you need to use a scavange pump and a large return. Didnt you have a scavange on there before?
Oiling problems suck, I am really pissed about my turbo leaking because this is the first Porsche motor that I did that didnt leak oil and now for this b/s.
Candy, thats what I did minus taking the exhaust off. I saw that the turbo has about a drop every second for about 6-7 mins. after the car is shut off. All those drops eventually add up enough to rise and leak past my seals. I have that little ball check valve and it still dont stop it, I think I need spring loaded unit from 996 TT
Kris @ Tech9
86' 930/GT-40R Sold
Old 05-26-2007, 04:37 AM
WydRyd's Avatar
Candy makes a good recommendation above... do what he says! It's unlikely you have TWO bad turbo's, but you never know
Merv
'89 911 Turbo Cab
Old 05-26-2007, 01:48 PM
Maltese Falcon's Avatar
SpeedRacer,
if you've run these turbos for awhile with the "Lazy" oil return problem you could have saturated the compressor (oring) seal and the turbine (ring or carbon) seal to the point where they are failing . This really won't allow you to determine if your other remedies are correcting the original oiling up problem.
I would send the units out for re-sealing (not expensive ), any turbo rebuilder of Garretts can do it.
Are your Garretts dry style or wet style ? Only dry turbos should be used on an air cooled engine, as the wets are designed to carry coolant thru them. A Garrett engr @ SEMA explained to me that a wet style turbo will eventually fail if run w/o coolant.
On the oil drains, I've only used #12 for the past 30 years w/o problems. Gravity drain into any available valve cover, chain cover ( circa BAE style) and even the case -- I've done this with xlnt success. What you need to avoid is draining into the oil level--you need to be slightly higher than the oil level.
Positive displacement 12V pumps work OK, but fail when people leave them running w/o any oil running thru them, such as key on / engine off.
Don't give up !
Marty
Porsche builds the 21st century 9146
so easy...even a Cayman can do it !
Old 05-28-2007, 09:47 PM
The turbos are brand new. They only have about 15-20 min of run time on them. I am running oil through the water passage.
Old 05-28-2007, 09:52 PM
Speed, that may be your problem. The coolant chamber is not designed for oil. The Garrett eng'r told me to run a seperate coolant tank, pump, lines and pressure cap , if I was going to put their wet turbo on an air cooled.
That's why I use turbonetics dry style , ceramic BB turbos--I didn't want to carry all of the coolant accessories.
You may want to contact tech at Garrett and figure it out .
They are in Torrance CA.
Marty
Old 05-28-2007, 10:02 PM
