mark '87 930's Avatar
Before I continue on this path..
Before I continue on this path I will start by putting in fresh 94 octane pump gas in the car (sonuco ultra here in Canada). After much reading, this sounds like the most logical first step. I have raised the stock boost slightly so I could only assume that 91 is no longer the 'minimum' requirement. Once I have that in the car, I'll listen again to check for detonation and proceed to ratarding the timing a tad If I need to (I may ask a few questions about the process there.. be patient with me, I'm learning!).
From the LM-1 I gather I have enough fuel.. just not the best fuel.
It's a US car.. 26* you mean at 4000RPM for advance (which would mean having the vacuum hose disconnected right)? I presume there is a notch indicating the mark on the pulley.
Is stock 29degrees?
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 04-01-2007, 05:28 AM
3rd gear pull looks better...
Thanks for looking at these things guys. I appreciate the help.
I dialed back the boost a little (to about 10psi ~.65bar) because this detonation scares me (as it should) and all was good this run, but I hope the 94 octane gas allows me to up it a little. I ran it through 3rd to about 5500K (I still haven't figured out why the RPM gauge reads low).
Looks much better, although I think I need to richen the mixture screw a tad more.
1956 Chevy 3100
Old 04-01-2007, 06:48 PM
A fellow Pelacanite
NathanUK's Avatar
12 AFR is good, lower is too rich and you will be washing the oil away from your rings.
Seems you might need some help from Brian Leask with his RPM solenoid setup.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 04-03-2007, 02:28 PM
more logs with K27S and IC installed
Here are 2 higway runs at WOT.. Since my last post I have installed a K27S. the first run I had a small boost leak. My Boost gauge clamp came loose, so the second run is much more accurate.
For both runs, the first bit is 2nd gear.. then all of third to redline, and then a short bit in fourth (I ran out of room). Sorry no RPM's this time, for some reason that doesn't work at all now!
I suspect that once I check my injector for cylinde #5, it may be even richer which would require a small amout of additional tuning.
No comments on my shifting time please... lol
1956 Chevy 3100
Old 05-19-2007, 03:56 PM
Me like track days
Craig 930 RS's Avatar
At .9 bar, twin plug, 22 degrees timing, K27 HF turbo, adj WUR. etc - I MUST run a mix of race and 92 premium gas on the road or clatter, clatter.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 05-19-2007, 04:05 PM
I'm running Sunoco 94 now, no exceptions. Pinging has disappeared and I know my AFR's aren't half bad.
1956 Chevy 3100
Old 05-19-2007, 04:21 PM
I don't do any track at all, it's basically just bursts on teh highway when I get a chance.
she runs good so far.. so I'm not going to worry to much about the idle AFR. She's real rich when cold, but makes her way up to 12.5 or so once warm.
1956 Chevy 3100
Old 05-19-2007, 06:57 PM
A fellow Pelacanite
NathanUK's Avatar
They seem pretty good. Good job.
Old 05-20-2007, 08:12 AM
