Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
930gt-40r's Avatar
compression ratio
On a 3.3 motor with stock pistons (97 mm) that have had the edge milled (to clear head) acting on a 3.6 crank, what would the compression ratio be? Keep in mind that the 3.6 crank is 2mm longer stroke.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 03-31-2007, 06:01 PM
930turbo's Avatar
Just the displacement increase alone would yield 7.63. However, the unknown is the volume remaining that was not machined off to clear the head. Chances are, the actual result would be higher.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 03-31-2007, 08:35 PM
930gt-40r's Avatar
so you dont think that it would be high compression like 9 or 10:1? The pistons only had the edges milled down to clear the heads.
Kris @ Tech9
86' 930/GT-40R Sold
Old 04-01-2007, 05:15 AM
My 3.4 with 98 mm pistons with the new 3.6RS crank resulted in a compression ratio of 7.72
Olli Selander
1989 930 - 3.5l - M48 - G64/51
Old 04-01-2007, 07:18 AM
930gt-40r's Avatar
Oms, What piston crown hieght did you use? Did you get custom pistons?
I need to get the exact formula in order to calculate it.
Kris @ Tech9
86' 930/GT-40R Sold
Old 04-01-2007, 11:19 AM
The pistons are 98mm Mahles which have flat tops but I'd need to get the details (numbers) going into the formula from my builder. You may have seen this already, but just in case, here's a thread dealing the compression ratio calculation:
http://forums.rennlist.com/rennforums/showthread.php?t=325101
Olli Selander
Old 04-01-2007, 01:54 PM
930gt-40r's Avatar
Thank you, that was very informative- Im thinking the C/R will not be that high which will leave nice room for boost to be squeezed in there.
Kris @ Tech9
86' 930/GT-40R Sold
Old 04-01-2007, 02:27 PM
cycling has-been
bkreigsr's Avatar
probably a dumb question, but doesn't the effective C/R change when the chambers get boosted?
anyone know an equation?
Bill K
Old 07-18-2007, 07:28 AM
930turbo's Avatar
Yes, the effective - or dynamic - compression does change under boost. It is not directly proportional to the increase in absolute pressure as the effeciency of the engine will cause a reduction. More air forced through the same size holes (vavles, intake, etc.) will result in less air overall. This is one of my favorite links for approximate calculations;
http://www.turbofast.com.au/javacalc.html
Old 07-19-2007, 11:54 AM
cycling has-been
bkreigsr's Avatar
thanks, pretty cool link.
I estimated VE at 70% and the numbers came very close to what I was expecting for the 3.0 L.
Is the Volumetric Efficiency estimate black magic?
Bill K
Old 07-19-2007, 12:42 PM
