GaryR's Avatar
Send a message via ICQ to GaryR
Fabspeed Single out and B&B headers.. Pictures of an install?
I must be doing something screwy. I've tried attaching the connecter on the K27 outlet every way possible, tried the muffler every way possible, and two things seem wrong. First, the muffler is out from the original mount bracket a good inch but sits square and level ( A weird two-piece bracket came with the muffler but I see no bolts the holes will line up with). Secondly the B&B oil tank is in the way of mounting the tailpipe. I'm sure it must be something i'm doing ass-backwards... If anyone has instructions they can scan and email or some pics (or just advice from a BTDT guy) I would sure appreciate it as I want to wrap this puppy up!
Thanks!
Gary R.
Old 04-07-2007, 02:44 PM
lite75's Avatar
Gary
you may need to index the center section of your turbocharger to get the oil tank to clear the exhaust, I had the same problem with my B&B install. Not sure about your muffler set up.
Dan
Old 04-07-2007, 10:22 PM
GaryR's Avatar
Thanks for the reply Dan. Again, the muffler goes on fine, is straight / level and as soon as I figure out where the Fabspeed mount bolts on (I'm told it bolts to the engine near the oil temp sensors) that part is good to go. Sounds like I need to modify the tailpipe.. maybe i'll just put a 90 degree elbow on it and shoot it straight out the rear instead of trying to zig-zag around the oil tank.. have to look at it again today.
Gary R.
Old 04-08-2007, 04:58 AM
magic930's Avatar
The mounting hardware might assume that you have the air conditioning bracket.
Old 04-08-2007, 07:54 AM
