Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
GaryR's Avatar
Send a message via ICQ to GaryR
CV joint question
After seeing the condition of one CV I decided to replace all of them and rehab the axle shafts. In doing so I lost track of which way the shafts go on and see no mention of it anywhere. On one side of each shaft there is a raised "rib" (shown circled in the picture attached). Does it go toward the tranny or wheel (or does it matter as long as both are the same?)? Also, is there an "inside" or "outside" on the new CV joints? I see no indication they go a certain way but wanted to ask before I assemble/grease them..
Thanks!
Gary R.
Old 04-03-2007, 01:32 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
i looked on my car and the rib is to the wheel, ive heard you can swap them though from a porsche mechanic , keeping them the same way just swapping left to right.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-04-2007, 04:15 PM
GaryR's Avatar
Thanks H20, that's where my shop said he believes it goes but he also said he's pretty sure it won't matter as long as they are the same on both axles..
Gary R.
Old 04-04-2007, 05:01 PM
h20cooled7's Avatar
no problem with the swapping thing you have to keep the rotation the same , he says its good for the wear of the joints(even) he also said use a few drops of diff fluid in the joint.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-05-2007, 02:39 PM
GaryR's Avatar
CV's are in, axle's installed! Biggest pain was not messing up the damn gaskets and dealing with Swepco grease all over the place... DONE!
Gary R.
Old 04-05-2007, 03:41 PM
h20cooled7's Avatar
Gary
Im gonna burn up a day rebooting mine this weekend,I'll be feeling your pain. just rebushed pedal assembly new clutch cable and try adjusting my accelerator pedal so theres no dead spot . hope it works out well ,good luck
Pete
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-05-2007, 04:42 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
