Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
"I wuz the liquor..."
sand_man's Avatar
Exhaust gaskets
I've got about 7,000 miles now on my new engine and noticed last night when I was under it, that my number three exhaust port appears to have a small leak between the header flange and the port. I can also hear a small exhaust "tick". I'm running B&B headers with the upgraded Performance Developments stainless exhaust studs.
When I built the engine, I just used the basic exhaust gaskets that were provided in the Victor Reinz seal kit. I suppose that I can try to snug the nuts up, but I'm afraid the gasket might be toast at this point. Can someone tell me if there is an "upgraded" exhaust gasket? As some of you know, it's no fun removing headers, so I'd like to avoid this for a long while if possible.
Thanks,
Jeff
-jeff
Old 04-05-2007, 07:13 AM
sand_man's Avatar
I guess the "search" feature would have been my freind!!!
Exhaust flange gaskets: Any recommendations?
-jeff
Old 04-05-2007, 07:17 AM
I haven't read that other link, but I've always ordered metal gaskets from EBS. They are like $4.50/ea.
Brian
Brian Keith Smith
Competition Custom Paint
1983 930
My Track Videos
TEC3 EFI Conversion on 1983 930
Old 04-05-2007, 11:34 AM
sand_man's Avatar
Brian
Thanks Brian. Yes, if memory serves me correctly, I think I used the metal ones that came in the gasket kit. Maybe I'll check to see what our host sells.
-jeff
Old 04-05-2007, 11:56 AM
930gt-40r's Avatar
Sand_man- My B&B's always had leak problems the first few times I used them; the stock metal gaskets should work good, you just have to go underneath her and keep cranking the header nuts back down. Once I got the nuts to stay tight, they never leaked again.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 04-05-2007, 12:17 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Not on my current car, but I've had to go back and tighten mine as well after installing on my old 911SC
Old 04-05-2007, 05:16 PM
Banned
Always add a good anti seize compound to those studs!!, Candy.
Old 04-05-2007, 05:28 PM
930gt-40r's Avatar
Yes, this is a must.
Kris @ Tech9
86' 930/GT-40R Sold
Old 04-05-2007, 06:08 PM
WydRyd's Avatar
Yes, tighten your nutz!
BTW, I've heard of people running the C2T gaskets in conjunction with the 930 gaskets, for extra sealing. Not sure if it's really required though
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-05-2007, 06:53 PM
Just to clarify - the metal ones I bought were not the ones that normallyy come in the gasket set. They are just a totally different kind of metal gasket - with 2 sheets of metal, and some sort of material in between - they look like stainless steel...
Just FYI
Brian
Brian Keith Smith
1983 930
My Track Videos
Old 04-06-2007, 04:57 AM
930gt-40r's Avatar
Those are the ones that I use, I also put a light bead of copper silicone on them and then tighten them multiple times.
Kris @ Tech9
86' 930/GT-40R Sold
Old 04-06-2007, 05:27 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
