Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
mark '87 930's Avatar
K27 turbo intake rubber/silicone tube
I'm trying to install this K27 and I a unbelievably frustrated. The original tube that makes the connection from the metal pipe to the turbo intake is old and cracking.. so I needed to replace it.. I purchase what I thought was the equivalent silicone turbo hose (2 3/4") but the thing just doesn't fit onto the turbo. I measured the turbo, and sure enough it's 3", enough so that the hose doesn't stretch AT ALL.
Add MANY colorful adjectives where you can up above because I deleted them time after time thinking I can't type that here!!
So now tomorrow is good Friday and I won't be able to get another hose. That being said, should I get a 2 3/4" to 3" transition hose, or should I just get a straight 3" hose and clamp it down. I ask because this is the intake, and non pressurized.
Sincerely,
Frustrated as all hell
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 04-05-2007, 05:39 PM
WydRyd's Avatar
Just get a 3" to 2 3/4" silicone reducer. Thats the simplest solution I'd say.
The OEM turbo has a 2 3/4" OD on the compressor/cold side. If you have gone with a K27 with an "S" cover, then yes, it'd be 3.0" OD. You'd need a reducer to interface the new compressor to your existing intake pipe.
I understand how you feel... little things like this can really put a damper on upgrades
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-05-2007, 08:18 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
