40mm Tial Wastegate on a 3.0SC??
I know that the norm for all you 930 turbo guys is to go with the 46mm Tial wastegate but as I am collectively gathering parts to convert my 3.0SC motor over to turbo and am thinking since I will be going low boost that 46mm may be overkill and that a 40mm will probably work fine.
So my question is do you think that a 40mm Tial wastegate will be suitable and does the 4 bolt 40mm Tial gate bolt up to the 930 headers?
BTW, the plan is to use the 930 Euro headers that I already have and a K27 turbo.
Old 04-09-2007, 01:45 AM
iamchappy's Avatar
40 even 38 will work fine, cant help you with the mounting.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 04-09-2007, 06:17 AM
WydRyd's Avatar
The 40mm won't bolt up to the 930 headers... different flange pattern. You might want to try looking for a flange converter for the TiAL wastegates. Someone like ATPTurbo might have them.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-09-2007, 10:35 PM
I supply 38mm with the kits that we offer and you can upgrade to the 46mm if you wish. let me know if you need a 38 or a 40 I am a tial dealer
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 04-10-2007, 06:13 AM
