-   -   964 cam timing (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/340555-964-cam-timing.html)
rg500930 04-10-2007 04:56 PM
964 cam timing
can someone tell me the cam timing for 964 cams in a 3.3l 930
930turbo 04-10-2007 06:05 PM
1.16 to 1.36 mm @ TDC
Candelaria 04-10-2007 06:46 PM
Those cams on a 930, you can go up to 1.4mm, no problem, Candy.
930turbo 04-10-2007 06:55 PM
The higher the spec, the more advance you build in.
Candelaria 04-10-2007 07:10 PM
The faster it will move out of the hole! Candy.
rg500930 04-10-2007 09:11 PM
thanks for the info
WERK I 04-11-2007 07:48 AM
Is the spring height the same as in the stock 930 cams?
Candelaria 04-11-2007 08:24 AM
They should be adjusted per 964 specs, Candy.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
