Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
964 cam timing
can someone tell me the cam timing for 964 cams in a 3.3l 930
Old 04-10-2007, 03:56 PM
930turbo's Avatar
1.16 to 1.36 mm @ TDC
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 04-10-2007, 05:05 PM
Banned
Those cams on a 930, you can go up to 1.4mm, no problem, Candy.
Old 04-10-2007, 05:46 PM
930turbo's Avatar
The higher the spec, the more advance you build in.
Old 04-10-2007, 05:55 PM
Banned
The faster it will move out of the hole! Candy.
Old 04-10-2007, 06:10 PM
thanks for the info
Old 04-10-2007, 08:11 PM
Forced Induction Junkie
WERK I's Avatar
Is the spring height the same as in the stock 930 cams?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 04-11-2007, 06:48 AM
Banned
They should be adjusted per 964 specs, Candy.
Old 04-11-2007, 07:24 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
