Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Faulty Aftermarket Boost Gauge?
Anyone have experience with failing 3" boost gauges that replace the clock? I am getting really erratic readings on my gauge. Everything seems pretty normal until it climbs up to 1 B and then the thing starts going nuts. Swings back and forth between .9 and 1.3 B.
Its driving me nuts. I have tried swapping TiAL boost springs... and then even putting the stock wastegate back on.
Help!
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 04-12-2007, 05:37 PM
check the gauge with compressed air. Regulate the air, build up to 1.5 bar. If the gauge won't hold the reading you've found the problem
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 04-16-2007, 08:19 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
