oil leaks on headers
Thought I fixed my oil leak problems but now I'm stumped. Originally thought it was the scavenge pump and replaced the o-ring and gasket. Still leaking, is the cam seal behind this a common problem? How easy is it to replace?
Thanks-Jeff
Old 04-15-2007, 09:26 PM
930gt-40r's Avatar
I think any leak on these cars are common, Ive seen the leaks come from anywhere and everywhere. Im not sure which seal your talking about- is it the cam seal on the back of the motor closer to the cab? If so those can be done in the car. Depending on how mechanicly inclined you are, but they are not terrible to replace.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 04-16-2007, 05:46 AM
930gt- I know oil leaks are common but this one seems a bit too dangerous. I can watch it drip while the car idles. I thought it was the scavenge pump, drivers side back of motor, but its behind that. I think the only thing left is the cam seal. Correct?
Thanks- Jeff
Old 04-16-2007, 06:19 AM
930gt-40r's Avatar
The scavange pump would have to have some severe problem to start leaking like that. The cam seal I believe holds residual pressure from the cam journal, so if it is really pissing, you are probley right.
Kris @ Tech9
86' 930/GT-40R Sold
Old 04-16-2007, 05:41 PM
mark '87 930's Avatar
I had a leak out of there and replaced the CAM seal as that was the one leaking. While I was in there, I replaced all the others as well, including the little paper gasket in between.. My cam seal was bad for sure, as there was a small pool of oil inside the bottom of the housing when I removed the pump. It's easy to do.
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 04-17-2007, 06:05 AM
kellcats521's Avatar
There are 4 seals in this cam/pump setup:
1) The paper gasket on the end of the cam box.
2) An oil seal that is driven into the face of the scavage pump/smog pulley housing that screws to the cam box which rides on the cam drive. The cam drive has the smog pulley bolted to it and the smog pulley bolts are what spins the scavage pump drive. This seal, along with the gasket keeps oil from the rear cam bearing from leaking out.
3) A small oil seal on the scavage pump drive that keeps oil that is inside the scavage pump from leaking out on the drive stub.
4) An o-ring inside the scavage pump itself.
The OEM top-end gasket kit for a 930 includes ALL of these seals - I'll offer that it's important to replace all of them if you have any leaks in this area, as it's difficult to really tell what is not holding oil.... I'm sure Pelican will sell them ala carte, but you may need to call vs. order online.
Pat Kelley
Old 04-17-2007, 06:39 AM
Thanks for the info guys. I will order the seals and gaskets from Pelican. Any tricks or tips on the cam seal removal and install? I already replaced the seals on the pump itself, guess I should have looked closer at the cam seal.
Thanks Again- Jeff
Old 04-17-2007, 02:58 PM
930gt-40r's Avatar
I used a right angle pick- stabbed the seal - turned it sideways and pulled it out.
Kris @ Tech9
86' 930/GT-40R Sold
Old 04-17-2007, 06:22 PM
