Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Noah Holcomb's Avatar
Results with 3.2 Carrera heads on a turbo engine?
I have been messing around with a couple different engine software simulation packages along with crunching numbers on my own. Maybe I have made an incorrect assumption along the way but I am obtaining some unexpected results regarding 3.2 heads on a turbo engine. In fact some of the estimations based on the information available show the 3.2 headed engine not performing as well as the 3.3 engine! I did not expect this outcome at all!
So, for all those running 3.2 heads on your turbo engine who have a dyno graph could you please post those dyno results along with a basic engine build sheet containing key parameters.
Old 04-17-2007, 07:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
WydRyd's Avatar
Heat is a killer in air-cooled motors, whether you're using 930 heads or Carrera heads. As long as you keep your boost levels to within moderate levels and have proper A/F's, EGT's, oil and inter-cooling, there's no reason why it shouldn't live on a race track.
Personally, I wouldn't go running sustained boost levels of 1.3bar on a race track, but 0.8 - 1.0bar would be fine I'd think.
My Carrera is purely street and has been turbocharged for many years. No issues with cracked/overheating heads whatsoever.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-17-2007, 07:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
kellcats521's Avatar
Re: Results with 3.2 Carrera heads on a turbo engine?
Noah,
I'd take a good look at cam specs - I'd expect that the 930 cam won't benefit much, if at all from the 3.2 head's bigger ports. Also, from what I've done with engine analyzer, it didn't seem that the program simulated forced induction accurately, especially with respect to cam profile. Most of the blown cars that I saw seemed to make more hp and torque than engine analyzer predicted.
Good luck!
Pat Kelley
Old 04-17-2007, 08:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
The 930 cam didn't do well with the 3.2 heads according to my simulation results. Most of the simulations I have ran used the EVO GT2 cam and the 3.3 heads still seem to give better results. This can't be the case.
Old 04-17-2007, 08:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Me like track days
Craig 930 RS's Avatar
How about large port SC heads with a 964 cam?
I was quite happy with a prety level torque curve and a nice HP line - 438 RWHP/413 TQ.
I am convinced that the SC heads help more than just a little.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 04-17-2007, 08:28 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Crotchety Old Bastard
RarlyL8's Avatar
It would seem to me that ported 930 heads should outperform stock Carrera heads due to the metalergy involved and the tiny 0.1L advantage.
Old 04-18-2007, 06:47 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Me like track days
I know it seems odd, but according to some of the top engine builders, it turns out that the metallurgy involved does not make a difference in any aspect.
I'd assume the Carrera head have larger ports and valves than a stock 930 head - the SC heads used on my car (from 78-79) certainly do.
In the old days, the inefficient turbochargers pretty much relied on gas velocity to produce power - the modern TCs are so much better and pump so much more air that sheer volume becomes an issue........and a "bigger pipe" to deliver the goods becomes a goal, of which a part is manifold, heads, and in a different aspect, the exhaust.
Old 04-18-2007, 07:20 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
The Carrera heads absolutely have bigger ports, but valve sizes are equal. I agree that the metallurgy has no effect on performance, it will/would only effect which head exceeds it's thermal load faster or at a lower temp.
I think the boat has been missed here - Noah is using a computer simulation (like the program "Engine Analyzer") to predict performance of different components, of which the program is NOT showing significant or measurable improvement when using the SC heads vs. the 930 heads. I expect that Noah has imput all of the specific parameters of each head and cam combination, along with intake and boost info, and the program is predicting TQ and HP.
Again, my experience with the specific program 'Engine Analyzer' was that boosted applications tend to be a bit conservative. The program seems to lessen the significance of port size and volume in boosted applications compared to looking at them in a N/A application. In other words, porting/enlarging the heads on a boosted motor produced bigger TQ/HP increases on the dyno than Engine Analyzer predicted.
The program seems to follow the old mantra that porting doesn't help boosted applications. While it's true that pressurizing the intake/cylinder will overcome some flow-related issues that would effect a similar N/A motor, the converse is absolutely not true - porting/enlarging a boosted motor's intake has just as much positive effect on TQ/HP as it does in an N/A application, and maybe more in some cases.
My initial comment regarding the SC head and 930 cam combo was related to what I expected the Engine Analyzer prediction to be - I expect that the 930 CAM cannot keep the valves open long enough to actually benefit from the increased port size of the SC head, irrespective of the boost or N/A application. I would expect that the bigger ports in the SC head need more cam to actually see any benefit, and I'd expect that a program like Engine Analyzer would predict the same thing.
I am curious if any Porsche performance shops are using programs like Engine Analyzer to work out the modifications they develop and/or sell. I do know that in many racing venues these programs are indispensible in developing engines for specific applications.
Pat Kelley
Old 04-18-2007, 07:56 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
I use small port SC heads on my 3.2ss motor. It runs fantastic and is fully boosted by 2600 rpm. I run a T4 though. I also am much lower HP levels@300+hp not 400+ I believe you want more intak velocity then anything. The bigger intakes slow velocity..
Ben
Current project 73 914-6 Gt project rusteration 2.4
Reproduction 914-6 oil tanks, 1-5/8" 914-6 heat exchangers source call 2623647426 or email mbconsulting21 @gmail.com
Old 04-18-2007, 09:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Kellcats521, I am using Engine Analyzer, along with another less powerful program. I think the problem is how this program along with others take such vast assumptions regarding the turbocharger. The data from the compressor map that is input into the program is the peak island efficiency, the pressure ratio, and cfm flow at the center of the peak efficiency island. The only data from the turbine side used is the A/R ratio, housing diameter, and approximate efficiency. Seems to me a large table of values obtained from the compressor map should be required be to generate reliable outputs.
Has anyone here used Dynomation software?
1985 Porsche 911 M491 option 55K miles
1985 Alfa Romeo GTV6
CRG Heron Daytona CR125 Shifter Kart
Old 04-18-2007, 11:11 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Me like track days
Velocity vs. Volume -- the two interact, but in general the older turbo inlet systems relied on velocity and the newer on volume.
Old 04-18-2007, 12:47 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Noah,
I have not done a lot with EA on turbo motors, but I have seen/done many with superchargers - mostly the centrifical blowers which should on the pressure side be similar to a turbo. As I said, our EA predictions were usually off compared to real dyno data. It was prolly operator error in not spending enough time getting the blower data input correctly.
It is a neat tool, but it can get you waay off without keeping some real-world experience in the equation.
Pat Kelley
Old 04-18-2007, 07:17 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
