-   -   Garettson intercooler install (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/342039-garettson-intercooler-install.html)
bcoats 04-18-2007 08:22 PM
picked up a Garettson/Andial intercooler today, anyone have experience installing one of these? It has only one connection on the low temp side, looks like to fit lower tube from the air bypass valve? Also other connections in the back not sure about, any advise is greatly appreciated, I'll try and post some pictures soon. Also wondering if I need a newer BOV for this, heard conflicting stories.
Jim2 04-18-2007 10:10 PM
Similar unit to this?
From left:
Black vertical hose goes to idle speed bypass valve
Tubular mount with ~4" bolt
Connection to throttle-body ~ 3" dia.
Orange hose to blow off valve
Vertical aluminum tube went to deceleration damper valve
Port for boost Gage
Intercooler mount
Port for high boost fuel pump cut
Port for wastegate signal
http://www.members.shaw.ca/fstrnu/intercooler.JPG
bcoats 04-19-2007 08:28 AM
Thanks Jim but mine's a bit different, will post pictures later
thomas682 04-24-2007 05:05 AM
BOV assembly
Jim,
Where can I buy a BOV assembly, elbow and tube extension like the one shown in the lower right corner of your photo.
Can this unit be installed using the stock intercooler?
I would like to remove the stock BOV assembly and clean up the top of the engine... decel valve etc. Less metal to heat soak might equal lower slow speed engine bay temps, no?
Anyone know why the engineers changed to this new design?
thomas
NathanUK 04-27-2007 10:38 AM
Less weight & bulk.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
