Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
BadMonkey's Avatar
930 uprgades
Need your help Guy's, I got the green light from the Warden to allow a few dollars to be spent on some upgrades for my 1987 stock 930. I would like to get +/- 400 HP after it's all said and done. In the most general terms what do I need to get to make this happen on my car. Your opinion please, I guess I will do the "bolt-on" swap items first and then move on to the inside if you think it's required although I've read in here somewhere that I should be able to get 400HP without going into the heads, pistons, FI, etc. Thanks to all.
MV
02 ZO6
70 454 LS-5
92 XJS V-12 conv.
87 930 stock
Manny V
Old 04-24-2007, 01:15 PM
WydRyd's Avatar
Aftermarket headers, free-flowing muffler, K27HF-S, aftermarket intercooler, 1.0bar boost spring & some form of fuel enrichment.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-24-2007, 03:41 PM
Crotchety Old Bastard
RarlyL8's Avatar
400HP at the crank right?
You'll need to go into the engine to get 400HP to the wheels.
Old 04-24-2007, 06:29 PM
David's Avatar
I think you'd be very happy (for now ) with Merv's suggestions. I'd go with Imagine Auto's fuel head mod for the additional fuel requirements.
2014 Cayman S
2011 Cayenne Turbo
Old 04-25-2007, 11:26 AM
RarlyL8's Avatar
You likely don't need the fuel head mod unless your going into the engine to get >400RWHP. Do the bolt-ons, check your A/F ratios then decide what comes next.
Old 04-25-2007, 07:06 PM
If you go with a Highflow S turbo I would NOT put a 1 B spring in. I was getting way too much boost.
I would first define what you want to spend and then go from there.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 04-26-2007, 11:15 AM
WydRyd's Avatar
A K27-7200 will flow upwards of 400+HP I believe, so it would be a better match for your application and spool very nicely too.
Merv
'89 911 Turbo Cab
Old 04-26-2007, 03:03 PM
BadMonkey's Avatar
Smile 930 upgrades
Thank you all very much. I sincerely appreciate all the good info and "How to's" provided. I'm off to the parts store to start the gathering..... may/will need more advice as I get into it. Again, thank you for your time.
Manny V.
I'm not here for a long time, I'm here for a good time
Manny V
Old 05-01-2007, 01:06 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
