930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Porsche Crest idle ?
how long can you let a 911 turbo idle before it gets to hot?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-27-2007, 09:45 AM
WydRyd's Avatar
These air cooled motors don't like to idle for extended periods of time. I know with my car, if I'm idling at a stand-still in traffic for extended periods (15+ minutes), I can see the oil temps rising and this directly affects performance and responsiveness from the motor.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-27-2007, 03:08 PM
h20cooled7's Avatar
i was just wondering because i was setting my timing and was letting it idle for 20 minutes and if i cracked the gas and my oil light came on when it down in rpm. i just switched to rotella 15w 40 and the oil gets real thin. the temp was around 100 degrees this is the hottest i seen this car run but summers right around the corner.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-27-2007, 05:54 PM
Crotchety Old Bastard
RarlyL8's Avatar
Do you have a numeric gage or the one with a couple of lines and then a red area? If you have the latter you can actually see tiny numbers on the outter edge of the lines if you put your eye at a severe angle and know where to look. The numbers are in *C. The line in the 9:00 horizontal spot or mid-gage is 105*C or 219*F.
Generally I believe anything above 230F is too hot. If it starts to creep up during tuning I take it out for a cool down run and then continue tuning if needed. You can also put a big fan on the front wheel well cooler.
100*C or 212*F is not a problem.
Old 04-27-2007, 06:21 PM
h20cooled7's Avatar
I have the numeric gauge , you guys put my mind at ease. I was like crap what do I have to fix now. I am gonna use the fan in front of the cooler trick,Niceeeeeee
Pete
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-27-2007, 06:28 PM
