Engine for a Porsche 917K
I'm planning on building a replica Porsche 917. The original race car had a turbo charged 12 cyclinder air cooled. These are long gone away now, although a couple survive in museums and some in original cars.
I don't know much about Porsche's, but I want to keep the 917 somewhat "authentic". I would like to put in the most powerful air-cooled Porsche engine I can. I've heard that the later 911 turbos have water cooled heads - there may be space for small radiators at the very rear of the 917, but the front really only has space for an oil cooler.
I'm not looking to build the engine myself - I want it done professionally. It needs to be able to run on street gas, but I can put race gas in it at the track.
Thoughts / suggestions on where I should start looking? I need names of reputable builders.
Old 05-01-2007, 08:16 AM
call henry@supertec 760-728-3062
He can get you started..
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 05-01-2007, 09:59 AM
Send a message via Yahoo to Lukesportsman
Stephen Kasper of IA. Build some bad turbos. Water cooled heads = big bucks...but if you have it to burn than a 962 engine would certainly make it scoot.
Ninemeister builds some wicked engines and offers probably the best aftermarket heads out there. Do a search on Rennlist also. They are across the pond so the exchage rate hurts.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v803996TT
Old 05-01-2007, 07:03 PM
dewolf's Avatar
these guy's might have some insight
http://www.duttondirect.com/dealers/profile/company:kraft%20werkz
In Heaven… the mechanics are German, the chefs are French, the police are British, the lovers are Italian and everything is organized by the Swiss.
In Hell…the mechanics are French, the police are German, the chefs are British, the lovers are Swiss and everything is organized by the Italians.
Old 05-01-2007, 09:27 PM
Jeff Alton's Avatar
That replicar will be nice and light. How fast do you want to go? A nice carbed 3.2 would work. A stock 3.6 would work. So would a mild 3.0 for that matter.
It all depends on your budget. No need to worry about authenticity as you are not putting a 12 in there. Build a nice motor with sharp throttler response and you will be happy.
Cheers
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 05-01-2007, 09:36 PM
If you're serious, get in touch with Kevin Jeanette.
He is.. Gunnar Racing
http://www.gunnarracing.com/
email is in his website
Old 05-01-2007, 10:04 PM
Crotchety Old Bastard
RarlyL8's Avatar
Got a welder? Put 2 flat six engines together as one. Be sure to post the project, I'd like to see it done.
Old 05-02-2007, 07:54 AM
Conservative Libertarian
Turbo_pro's Avatar
Supertec has history with projects like these.
http://forums.pelicanparts.com/supertecperformance.com
917 replica
1964 Lotus with a Porsche 2.0 twin plug.
Jim
"The [contemporary liberal] standard for smartness is
not achievement but glib rhetoric, smug airs and
presumptuous proposals.'
"Thomas Sowell
Old 05-06-2007, 05:52 AM
Noah Holcomb's Avatar
As getting the real flat-12 is not feasible and a flat-6 will not be the correct engine why not looking into other engines for this car that are not made by Porsche. You could make a lot of power with a small block Chevy and spend much less doing so. Now lets see how many people criticize me for saying that.
Old 05-06-2007, 06:45 PM
Turbo_pro's Avatar
Take a $70 K chassis, add a $10K small block and end up with a rather plain kit car maybe worth $80K.
Build a some what correct high performance Porsche flat six and the sky is the limit. Bill Freeman sold this car a Barret Jackson for $178K.
If all you want is a Chevy powered car, buy a Z06.
With a 350 HP NA Porsche 6 this little car will scoot.
Add a turbo or two at say 600 HP and the performance will be world class.
I forgot the engine. 3.5 MFI 350 hp Porsche flat six.
Jim
"Thomas Sowell
Old 05-06-2007, 07:46 PM
I'd rather have a 700 + hp small block in the car. Do you want to go fast or do you want a car that is viewed by some as "correct" never mind a flat 6 is still not the correct engine.
Old 05-06-2007, 08:18 PM
Turbo_pro's Avatar
Originally posted by Noah Holcomb
I'd rather have a 700 + hp small block in the car...................
Why ?
Jim
"Thomas Sowell
Old 05-06-2007, 08:54 PM
Jeff Alton's Avatar
The flat 6 is half correct........
Cheers
Old 05-06-2007, 08:57 PM
WydRyd's Avatar
Why not just build up a 700HP twin turbo 964 flat6 motor? It'd reliably run 1.25bar of boost all day, every day
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-06-2007, 09:10 PM
A fellow Pelacanite
NathanUK's Avatar
There is no substitute ---- for capacity
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 05-08-2007, 01:19 PM
