Tires for an 88 930?
I need to find a set of tires for my 88 930 with stock 16X7&9's.
I have no idea of what tire or size to get.
Can anyone reccomend some nice gripping all season tires (rain but no snow) and the sizes? Maybe cost as well. This is a strictly street car.
Thanks-
Craig Backer
Old 04-29-2007, 07:41 PM
A fellow Pelacanite
NathanUK's Avatar
7's usually take 225's
9's usually take 265's
I would just use what the handbook recommends.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 04-30-2007, 10:29 AM
spence88mph's Avatar
205/55/16, 245/45/16 are the stock sizes for 7s&9s
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 05-02-2007, 03:49 AM
Nape75'911T's Avatar
Spence......
I thought 205/225 combo was for 6's and 7's....not for 930's....I believe Nathan is correct......
OK, I have this car, now things are out of control !!!!
83 930 Turbo....the car I have always wanted!!
K27 7200, Tial 46mm WG with straight pipe, Fabspeed Exhaust,B&B halfbay IC, Wevo mounts, Rennline floorboards, Rennline goodies, Optima mount, Elephant finned oil lines, widemouth cooler, high speed fan.
Old 05-02-2007, 06:08 AM
A fellow Pelacanite
NathanUK's Avatar
I might be wrong saying this but I thought all the 930's had 205 up front and 245 at the rear regardless of the later wider rear wheels.
I do suggest using what the handbook says though.
EDIT: Just got out my handbook, euro '81 930. Front 7x16 205/55 and Rear 8x16 225/50.
So, we were all wrong
Old 05-02-2007, 01:05 PM
kellcats521's Avatar
245's are factory correct for the 9" wheels
Pat Kelley
87 930
Old 05-02-2007, 06:10 PM
Just checked mine.....
205 front, and 245 rear, you are correct Nathan.......
Old 05-04-2007, 05:35 AM
wcc wcc is offline
wcc's Avatar
+1
From my '87 930 owners manual they are 205 front and 245 rear.
Bill
997.2
Old 05-04-2007, 05:40 AM
Re: Tires for an 88 930?
Thanks-
Craig Backer
I am assuming from your question that you want a size that works, and the combo that people tend to use is 225/50 and 245/45.
I see from the responses to this thread that everyone is assuming that you are only interested in running the EXACT stock specs from a twenty year old car. If so, then run the 205s.
If you want to know what most people seem to like, it is 225/50 and 245/45.
The tire selection is pretty bad, I would look at the Bridgestones at tirerack if you want longevity or the Hankooks at discount tires if you want a sticky performance tire which will wear quicker but work better at a track. Everything else tends to be bargain basement stuff.
Old 05-04-2007, 08:53 AM
A fellow Pelacanite
NathanUK's Avatar
My head is spinning from all these numbers
Old 05-04-2007, 09:44 AM
RSupdate's Avatar
Has anyone bumped up a size on the stock Euro16x 7 & 8" fuchs?
I am looking to keep the stock wheels but bump up a size from the factory 205 & 225 tire sizes.
How would 225/50 & 245/50 work? Any recommendations?
Thanks guys.
Johnny Riz
1973 911 Custom Euro 3.2L "Sports Purpose"
'10 Subaru WRX-STi Hatch - modded.
RGruppe#152
Early 911S Reg.#335
Old 05-08-2007, 03:57 PM
87 930...just bought a new set of Toyo Tr-1s. They were less expensive than some others... I was trying to get Falken FK 451/2 but could not find the rear size in stock... the toyos were offered up as a better tyre. I run Eagle F-1 on my series 7 and I like the v-tread pattern as opposed to straight line tread patterns. the previous set that came with the car had the Continental Conti's with the straight line tread... when I would take tight turns I would feel the tread flex a little... The Toyos have the V-pattern and a side wall support design that adds more stiffness to the center v-tread.. so far I like them....now once the tyres were mounted the owner starts showing me Fiske wheels that I could install ( 17 or 18 in) that he said would open up the selection of tyres.....I told him he was too late...if only he had made his move earlier......
yes tires are getting difficult to find for these cars.....
1987 930 -Guards Red
2001 740I sport Blk
2011 F-150 supercrew Blk
2014 X3 2.8 white
"What goes around comes around..."
Old 05-08-2007, 04:31 PM
Thanks guys.
I think you might want to consider 245/45 rears. The sidewall is not too squishy, and I think it would still fit on a 8 inch rim. You can double check with the tire manufacturer or somebody knowledgable at tirerack.
A 245/50 might work, I just don't really know if you will like having the extra sidewall. Kind of cuts down on the performance, I would think.
I imagine with either size rear on an 8 inch rim, you may want to run a decent amount of air pressure to keep the tire from being squishy on a 8 inch rim.
Old 05-08-2007, 06:54 PM
WydRyd's Avatar
I run Sumitomo HTR-ZII18" tyres on my daily driver and they are pretty good I must say.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-08-2007, 07:17 PM
