fifth gear LM1 log
I haven't downloaded the lm1 lately, and I recorded this run on sunday in fifth gear on the freeway.
I realized while it was happening that I should have used fourth, as I have in the past.
Also I forgot how "off" the tach is in the car, at the end of the run i was past 5000 + on the gauge, but looking at it today I was at 4600, then I remembered how far off it was at redline. LONG ways
This is even true for another car that's been run many times. I mean the needle needs to be buried to even come close to 6500. I've checked this many times, I get the same results everytime.
I remember again that fifth gear gives you time to look at the boost gauge and fuel pressure. Both max out somewhere between 3 and 4k rpms at just under nine psi and just under 80 psi fuel press
Fifth gear gives you time to look, fourth gear doesn't. The problem is fifth gear redline is way to fast, so you can log in fourth but can't look, and can log in fifth and look but can't get to redline without going to jail or hitting another car.
no really, cars come up fast at 120
Berate me if you want, but there are far more corrupt things going on in Louisiana than me speeding. Don't worry, I'm safe
Old 09-27-2007, 07:28 AM
I was gonna add, it's been a year now, and no problems, the only thing I've changed is the plugs to one number colder
Old 09-27-2007, 07:36 AM
Remember
The Turk's Avatar
Your graph lines are very smooth, did you use the "smoothing" function in the LogWorks software ?
Gary
1975 911S G50 3.5 Twin Turbo
Old 09-27-2007, 02:25 PM
yes, by one second, here it is without
Old 09-27-2007, 04:15 PM
Remember
The Turk's Avatar
That's still really smooth, mine tends to be a little more jagged.
As your probably aware, big lean spikes can be an indicator of miss-firing.
How are you posting those logs ?
Are you uploading the log file with the ".log" extension ?
Gary
Old 09-28-2007, 09:05 AM
control + print screen keys
open MS paint and paste
I embed in post from tinypic.com
it captures the window of whatever I have the mouse pointer in.
I don't know if I changed something but before it would capture the whole desktop, now its just getting the window,,,weird
Old 09-28-2007, 11:58 AM
A fellow Pelacanite
NathanUK's Avatar
Shift + Print Screen captures the whole screen.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 09-29-2007, 11:57 PM
