Got Boost?
throttle linkage w/3.2 intake
Most 930's with the 3.2 intake conversion have to reverse the linkage for throttle. I was checking out the cable actuated system on the 3.6 intakes and it seems as though this would be a good way to go.
Thoughts?
Pictures?
john
john bradshaw
comscc.com
porsche 930rs
SPA #227
Old 05-18-2007, 09:58 AM
David's Avatar
I reused my 930 bracket, but used the Carrera shaft, arms, and springs. The original throttle rod from the transmission bell crank to the engine worked fine.
2014 Cayman S
2011 Cayenne Turbo
Old 05-19-2007, 05:08 AM
You must of cut and reversed the manifold? I didn't do that so I am using stock Carrera stuff. Except I had to build a new rod down to the tranny cause of the G50.
I would see if I could make a rod to make it work.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 05-19-2007, 05:28 AM
David's Avatar
Nope, stock manifold in stock orientation:
2014 Cayman S
2011 Cayenne Turbo
Old 05-19-2007, 05:49 AM
David's Avatar
Here's a shot a little closer (and blurrier):
2014 Cayman S
2011 Cayenne Turbo
Old 05-19-2007, 05:53 AM
7.0:1 > 11.3:1
John, I reversed the direction of the ball stud on the 930 bellcrank to accept the Carrera rod which connects to the throttle body. At the time I considered buying the stock Carrera parts but figured it would set me back a week or so with delivery.
I'd estimate that building the parts to hold a cable sheath and integrating the cable onto your 930 bellcrank and Carrera throttle arm would be a similar amount of work to what I did. On the other hand what David is suggesting would be seamless with no modifications required.
Old 05-19-2007, 06:58 AM
David's Avatar
I did have a problem with the throttle not closing completely so I added a small spring inside the large spring on the throttle body.
2014 Cayman S
2011 Cayenne Turbo
Old 05-19-2007, 11:34 AM
Got Boost?
sorry, forgot to mention that I have decided to flip manifold 180 for more direct air flow
seems to be the way to go since I am having an intercooler custom built (bell)
john
john bradshaw
comscc.com
porsche 930rs
SPA #227
Old 05-22-2007, 07:35 AM
