F350Lawman's Avatar
No fuel????
Well I got stranded... only an 1/8 mile from home so no biggie. A friend pulled me into my driveway/garage with his pick-up. Here is what happened.
I was just pulling away from my house fairly enthusiastically but not brutally (warm car I had been driving and just stopped for something, car left running). When I shifted into 3rd I felt something wrong. I thought I hadn't put it fully into gear and it 'popped" back out of gear because the car just stopped accelerating. I realized it WAS in gear so put the clutch in and monkeyed with the gears and clutch thinking my gearbox was the issue.
I was moving fairly fast with both windows down and sunroof open so I guess I couldn't hear that the engine was the real issue until I saw the idiot lights and realized the car was/had shutting down. It seeemd to just slowly die...ljust ike a car that you've let run out of fuel feels.
Car cranks fine but I don't think I have fuel (tank is full). I played with and swapped all the relays and fuses without result. I grounded the overboost switch, no help. I amd prety sure I hear the box and pumps running. I am thinking I still don't have fuel because even when I crank and pump the gas 9just trying anything) I don't get that gas smell like a flooded motor would give. My other thought is the ignition switch, a few months ago the car ran with the keys removed or in the off position for about 15 miuntes and then shut off. I was never able to dulicate that behavior even though I have restarted the car several hundred times since then.
This car only gave me trouble once before when the CDI box went. Funny that was in the exact same spot about 1/8 mile from my house. What gives..do I have the Porsche equivalent of the Bermuda Triangle near my house?? Must I move??
Any help would be great. I will give it one days self medication at home an then it's off to the shop. I just don't have time to mess around too much. I jsut want to try the basic fixes/tests.
1987 930 - K27 7200 / DAS Full Cage / Blownsix Intercooler / BB Headers / Zork Tube / Tial 46mm / Adjustable WUR / RPM Activated Solenoid / Open Element Air Intake / Smart Racing 27mm Sways / 24 and 33mm Torsion Bars / Adj. Spring Plates / Wevo Strut Brace / Monoballs / Tow Hooks / Oil Cooler Scoop / Brey Krauss Harness Truss / Race Seats / XD-16 AFR Guage/ 17" Kodiak Racing Whees and Nitto NT-01 255/315s
Old 05-20-2007, 07:45 PM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
Check all your hoses in/out of the turbo.. This sounds exactly like what happened to me.. where one of the hoses came off the turbo..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 05-20-2007, 08:36 PM
kellcats521's Avatar
Sounds like a bad yellow relay (in the engine compartment, on the driver's side). This will shut the fuel off. Also the overboost sender (in the diverter assembly) can cause this problem if it fails.
Good luck!
Pat K
87 930
Old 05-21-2007, 03:24 AM
River Rat
Dave 86 930 Fl's Avatar
My suggestion, replace the fuse for the fuel pumps.
My car would not start last week, I visually inspected the fuse, swapped a new red relay in each position, did the same with the yellow relay and it would not start. Over the weekend I replaced the blue (25a) fuse in position six in the fuse box and bingo, started right up. Moral of my story, visual inspection is not good enough for these strange little fuses, just replace them (often) and everything will be ok.
Good luck, Dave
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 05-21-2007, 03:53 AM
A fellow Pelacanite
NathanUK's Avatar
Good luck, Dave
This is so true, BTDT and paid the price...
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 05-22-2007, 07:42 AM
F350Lawman's Avatar
I haven't had much time but the fuse swap doesn't seem to be helping. I will try some more when I get some more time. If I can't get it working by the weekend I will bring it in for professional help ;(
Old 05-22-2007, 05:54 PM
