Kirk911SC's Avatar
Angry Brake problem
Originally posted on Rennlist:
http://forums.rennlist.com/rennforums/showthread.php?t=354147
Any other advice?
Thanks!
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic.
- '87 930 - Guards Red - Sold
- '82 911SC - Grand Prix White - Gone
- '78 928 - Silver - Long gone
- '04 Subaru WRX wagon - Sold
Old 05-24-2007, 07:04 AM
Nape75'911T's Avatar
How much did you bleed.....
when you did the install Kirk?
I would take the advice on Rennlist, and bleed some more......
perhaps you got the cheaper Zimmerman rotors that come with the slight bend in them......lol......(sorry folks, inside joke).
Do you have a good bleeder? I can give you one if you need one.
Mark
OK, I have this car, now things are out of control !!!!
83 930 Turbo....the car I have always wanted!!
K27 7200, Tial 46mm WG with straight pipe, Fabspeed Exhaust,B&B halfbay IC, Wevo mounts, Rennline floorboards, Rennline goodies, Optima mount, Elephant finned oil lines, widemouth cooler, high speed fan.
Old 05-24-2007, 07:19 AM
Kirk911SC's Avatar
I never opened any lines....so no bleeding was done. I was able to move the calipers enough to pull the rotors off.
I have a pressure bleeder....although it leaks like a sieve sometimes!
Old 05-24-2007, 07:34 AM
Porsche Junky
mede8er's Avatar
Try changing the pads...exchange left with right...see if the problem transfers...
1986 930 RUF equipped
Old 05-24-2007, 07:56 AM
Kirk911SC's Avatar
Could this problem be caused by improper bedding? I did follow the manufactures instructions, but maybe I should have waited a little longer before braking hard.
The brakes never pulsed prior to the rotor/pad change, and I highly doubt the rotor is warped.
I've double checked the installation and I don't see anything wrong. When turning the rotor without the wheel installed there is definitely a "sticky" area during the rotation. Visually I don't see anything on the rotor....in fact I can still see the machining marks. Without the pads in, the rotor spins freely.
Can the rotor be cleaned? Steel wool, sandpaper, etc??
Old 05-25-2007, 11:42 AM
