sudo apt-get purge 930
equality72521's Avatar
Window trim
Why do some cars have chrome window trim and others don't? Mine has chrome front and no rear. Is that normal or did the PO remove the rear?
--clutch-monkey
Old 05-26-2007, 11:30 AM
Metal Guru
911nut's Avatar
I've never seen a 930 with bright metal trim before. The rear window gasket may be one for a 964 as they didn't have the trim stuck in them.
You should be able to buy the black trim pieces or replace the windshield gasket with the 964 gasket if you want all black trim.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 05-26-2007, 06:44 PM
So I can use 964 seals front and rear with no trim?
--clutch-monkey
Old 05-27-2007, 05:31 AM
A fellow Pelacanite
NathanUK's Avatar
Only if you buy the 964 front screen (glass) as well.
I have no idea about the back.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 05-27-2007, 10:17 AM
I guess I'm searching for black front and rear trim pieces then. Thanks
--clutch-monkey
Old 05-27-2007, 10:24 AM
A fellow Pelacanite
NathanUK's Avatar
If you think it is too expensive you could always roughen it up, mask it and finally spray it with an aerosol.
Old 05-27-2007, 10:27 AM
A fellow Pelacanite
NathanUK's Avatar
You may be able to sell your chrome one. Pull out the screen with the trim intact. Pulling out the trim first renders the trim useless...
Old 05-27-2007, 10:29 AM
True. Maybe Wurth Paint? I still need to source the rear trim, though.
--clutch-monkey
Well, according to PET, both chrome AND black were available from 1979 and down. I think I'll keep the front Chrome and look for a chrome rear to match. I've never seen it so I think I'll be different.
--clutch-monkey
Old 05-27-2007, 11:03 AM
A fellow Pelacanite
NathanUK's Avatar
Usually the door windows are also chrome to match.
Old 05-27-2007, 02:12 PM
Oh, damn. I guess I'm getting black again.
--clutch-monkey
Old 05-27-2007, 02:22 PM
Here is a pic of tonypeoni's 1979 930. He has chrome front trim and black side. I'm waiting to hear back from him about the rear.
--clutch-monkey
Old 05-28-2007, 07:41 AM
I have chrome front, rear, and I'm guessing sides as well (looks more like a brushed aluminum that has browned) on my 79 930.
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 05-28-2007, 11:46 AM
onboost's Avatar
76 through 77 had chrome front and rear and side window trim.
In 78 the side window trim was anodized blk which did not hold up well and that is the "browned" look you are seeing now. Blk front and rear trim on 78 & 79 I believe was an option.. some cars had it some did not.
Simplest thing to do is mask the car up, scuff all the trim with a scotch pad and spray it black. After scuffing wipe it down with prep-solv to remove any wax or oils. I would then use a zink chromate or etching primer to give the trim paint some bite.
Wurth and couple others make very good trim paint. Check at an auto paint supply store.
As far as the 964 trim goes.. I hear that the early seal and window ar the ones to use for the front. The rear seal should work on the stock 930 glass. Think I'm going down this road also when winter sets in again...very clean look.
Paul
RGruppe #180
Old 05-29-2007, 06:00 AM
Thanks Paul, that explains a lot.
--clutch-monkey
Old 05-29-2007, 08:40 AM
