WydRyd's Avatar
Lightbulb DP Tail...
I think I'm going to get this tail for my car, along with the 965/C2T bumpers & rockers all round. I also want to fit the aerodynamic DP / RUF style mirrors.
I know beauty is in the eye of the beholder, but I think it looks mega-tuff and will accommodate any size intercooler
What do you guys think?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-27-2007, 10:11 PM
A fellow Pelacanite
NathanUK's Avatar
I think it looks great. I would just have the cover plain black so as not to highlight the dp though.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 05-28-2007, 05:58 AM
Nape75'911T's Avatar
I think the car.....
should be able to back up the statement made by that tail!!!! By the looks of your signature......it shouldn't be a problem!!!!
I like it....agree with Nathan about removing the DP though.
Post photos when done!!!!!
Mark
OK, I have this car, now things are out of control !!!!
83 930 Turbo....the car I have always wanted!!
K27 7200, Tial 46mm WG with straight pipe, Fabspeed Exhaust,B&B halfbay IC, Wevo mounts, Rennline floorboards, Rennline goodies, Optima mount, Elephant finned oil lines, widemouth cooler, high speed fan.
Old 05-28-2007, 06:47 AM
WydRyd's Avatar
Thanks fellas. Yeh, I won't be having any DP logo on it. Just a nice chrome 996TT "Turbo" badge
Merv
'89 911 Turbo Cab
Old 05-28-2007, 01:32 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
do it man!!!!!!!!!!!!!1
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 05-28-2007, 02:19 PM
A fellow Pelacanite
NathanUK's Avatar
I think the dp is actually sunken into the cover, not just a sticker. I have never actually seen one though, only pics.
Old 05-28-2007, 02:28 PM
WydRyd's Avatar
The tail I'm buying is an exact replica of the DP tail above... no DP logo on it.
This kind of tail will allow me to mount the intercooler right above and in front of the engine fan. The fan will suck a tonne of air through the core, improving it's cooling efficiency dramatically
Merv
'89 911 Turbo Cab
Old 05-28-2007, 02:37 PM
Crotchety Old Bastard
RarlyL8's Avatar
Your cooling will definitely improve if the full bay is open at the top. Mine cools too well in the "winter" and I have to block some of it off.
Old 05-28-2007, 06:24 PM
WydRyd's Avatar
"COOL" - are you saying you are seeing close to ambient temps on the outlet of the IC in winter?
Merv
'89 911 Turbo Cab
Old 05-28-2007, 07:41 PM
lite75's Avatar
Hi
I've had a few DP replica spoilers, some are very heavy. Get the weight first before buy.
Dan
Old 05-30-2007, 06:35 AM
RarlyL8's Avatar
Intake charge cooling is a function of the efficiency of the intercooler, not so much the tail design. What I get in the "winter" (read - temps below 50*F) is an engine that won't warm up to 180* which causes the WUR to keep kicking down the pressure. I have to block off some of the tail opening so the engine won't cool off as much.
The intercooler does cool off much more due to the lower ambient temperatures of the air forced through it. Free power.
Those tails are heavy. I am looking for alternatives myself.
Old 05-30-2007, 07:42 AM
WydRyd's Avatar
Are they even heavier than the factory 930 turbo tails with the bulky rubber edging? The supplier said the DP extended tail weighs somewhere between 14-20lbs. He hasn't got one in stock to get actual weight, but said it's much lighter than the OEM 930 turbo tail.
Merv
'89 911 Turbo Cab
Old 05-30-2007, 03:01 PM
lite75's Avatar
the weight depends on the laminate and the design, some use the factory rubber and some have the rubber section replicated with composite construction. I kept the lightest one I could find out of three in my shop, give you a weight on it tomorrow. Its molded in one pc like the original DP spoilers.
Old 05-30-2007, 09:28 PM
WydRyd's Avatar
That'd be great, thanks. I'm sure the full f/glass unit will still be lighter than the OEM turbo tail. Not to mention the weight saving by replacing the impact style bumpers with full f/glass C2T units too
Merv
'89 911 Turbo Cab
Old 05-30-2007, 10:39 PM
lite75's Avatar
The one I have now is 20lbs.
The first one I bought was close to 30lbs, they seem to vary quite a bit. Just check before you purchase.
Dan
Old 05-31-2007, 12:48 PM
the 965/C2T bumpers are the ghey.
(that means damn cool right?)
Bill
Old 05-31-2007, 01:59 PM
WydRyd's Avatar
Dan
Thanks, Dan.
Is yours the Extended DP/Kremer 930 style tail, or the Extended DP RS3.8 style tail (like shown above)?
Merv
'89 911 Turbo Cab
Old 05-31-2007, 05:33 PM
lite75's Avatar
Its the Kremer style, think they both have the same bottom section with massive amounts of room for the intercooler. Give you alot of options on placement and size.
Dan
75 930, 76 930, 83 SC EFI turbo
Old 05-31-2007, 07:08 PM
WydRyd's Avatar
Yes, the extended base allows for much more flexible positioning of the i/cooler. Ideally, you want the IC's core right in front of the engine fan so it sucks through a tonne of air through the core for best cooling efficiency - an absolute must when running big boost
Merv
'89 911 Turbo Cab
Old 05-31-2007, 08:14 PM
mic mic is offline
mic's Avatar
Send a message via Yahoo to mic
Nice:
where can i get one?
Mike.
89 930 Turbo Cab.(soon for sale)
Old 06-01-2007, 05:25 AM
