-   -   help!!.engine reving really high on start up!! (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/349743-help-engine-reving-really-high-start-up.html)
stup 06-01-2007 02:23 PM
hi guys,just installed my engine in my 1992 3.3 964 turbo after rebuild,when engine eventually got fuel through and started the revs shoot very high to at least 3k++ at which point i keep just turning the engine off as i dont want it to rev any higher!!(tried it loads of times and keeps doing this)
i have removed the air injection from my car aswell,,checked throttle body which seems to be just a small bit open which i think is normal? and throttle cable seems to be slack...any sugestion where to start checking???...hope yous can help!
thanks
h20cooled7 06-01-2007 04:51 PM
let it run and check for vacum leaks?
stup 06-02-2007 01:00 PM
looks like may have been bent throttle linkage keeping the flap in throotle body slightly open now after a adjusted linkage so the flap is shut it ticks over fine
new prob thought check new post
h20cooled7 06-02-2007 05:23 PM
good find
