Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
15-40 Or 20-50?
Which one do you guys use? For most of its life the receipts showed 20-50 but for the last few years with the new owner they switched to 15-40. Which one should I run with a stock motor and 60K mile engine? I was told to use Castrol GTX 15-40 which seems to be for diesel engines.
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 06-05-2007, 01:04 PM
Send a message via AIM to Chuck Jones
I saw you posted this same question to the Rennlist board....and I think you'll find that most of the folks end up using the Castrol GTX 20-50....not all.....but most.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 06-05-2007, 02:49 PM
Thanks Chuck It looks like I'll do the same.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 06-05-2007, 02:54 PM
I use 20-50 amsoil
Ben
Current project 73 914-6 Gt project rusteration 2.4
Reproduction 914-6 oil tanks, 1-5/8" 914-6 heat exchangers source call 2623647426 or email mbconsulting21 @gmail.com
Old 06-05-2007, 04:51 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
most of the heavier weights are for diesels
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 06-05-2007, 05:14 PM
Automotive Monomaniac
Emission's Avatar
I use Mobil 1 15W-50.
Greater viscosity at the higher temps turbos are likely to spend their time at.
1986 - 930 Coupe / 2016 - BMW X5 xDrive35i / 2015 - Volkswagen Golf TDI 6MT / 2018 -Porsche 911 Carrera 7MT
Old 06-05-2007, 08:30 PM
wcc wcc is offline
wcc's Avatar
I used Castrol GTX 20-50, but recently switched to Mobile 1 15-50 full syn. Since the switch a very small leak developed that will be addressed at the next oil change. It'll be an easy fix. I switched because of the heat range as stated above. FWIW my car has about 60k on it.
Bill
Old 06-07-2007, 06:05 AM
Black968's Avatar
Oil Viscosity
I was thinking of going synthetic but was worried about leaks. Using GTX Castrol 20W/50 now but it seems to be getting hard to find in these parts.
Cheers
1986 930 Coupe Silver
1993 968 Coupe Black
2014 Ram 4 x 4 5.7L Hemi Sport
1999 Cobalt 23LS
2001 HD FLSTC (Carb)
Old 06-11-2007, 11:39 AM
David's Avatar
Castrol 20/50 here, I'd use Kendall 20/50 but it's getting hard to find.
2014 Cayman S
2011 Cayenne Turbo
Old 06-11-2007, 12:17 PM
I went with 20-50 this weekend, thanks for all the Info
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 06-11-2007, 02:04 PM
iamchappy's Avatar
20/50 Brad Penn green oil is the best out there now...Even better than Royal Purple for our air cooled (oil cooled) engines.
http://www.lnengineering.com/oil.html
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 06-11-2007, 03:51 PM
Wo ist die Rennstrecke?
DonE's Avatar
OMG - not the dreaded oil debate....again...
Old 06-11-2007, 04:00 PM
No...no more debate. He got his answer....everyone go home....
Old 06-11-2007, 05:02 PM
iamchappy's Avatar
I dont think of this as a debate, just facts. I ordered cases of the Brad Penn stuff last week. Any oil will work, some are better than others. Navarro put a lot of work into his research and works with air cooled Porsche engines.
Royal Purple would be the oil I would use if I didn't go with the Brad Penn stuff, as it comes with high recommendations also.
I use Amzoil in the tranny
87 924S
Lexus SC400
Lexus LS400
Old 06-11-2007, 05:22 PM
Emission's Avatar
+1
Old 06-11-2007, 05:49 PM
BReyes's Avatar
I would use fitty. Use to use Pensoil, and sold on benefit that Castrol is everywhere (slight different smell between the two). And the Castrol 50 has been very good.
Regards,
Bernard
Old 06-12-2007, 01:50 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
