LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
dewolf's Avatar
Re: With all due respect...
Originally posted by e p slick
With all due respect we mean no insult to any high powered Saab (Taxi cab) driver. Just trying to help you sort out the complexities of this mysterious life. Photo attached of what you might consider as an entry level vehicle. Then you can roll with the rest of us clowns.
EPS
LMAO!!!
Old 06-11-2007, 02:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
this is getting a little more vicious than expected...
turbojet: your Saab looks like you've put a lot of time and effort into it, which I can appreciate. Passion is often misunderstood.
Old 06-11-2007, 03:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
Thanks Rooked 930, I would like to get back on the subject. what is the diffrence between a 1989 930 and the previous years .
I know about the 5 speed tranny, but what is the good and bad about that? is 1989 considerd the best year for the 930 or is their down sides?. what was the top speed with the 89 tranny VS the 4 speed ones? and does it really takes about 1 hous to drop the engine out of the car? If so that is awesome. As much as I love working on my cars I hate when their is a bolt that requires removing half of the car to get to.
BOOST =
Old 06-11-2007, 03:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
A fellow Pelacanite
NathanUK's Avatar
No downsides to an '89 except for the higher price.
No tricky nuts or bolts removing the engine & tranny.
Still takes me nearly all day though to get the engine out. You remove the engine and tranny as one unit and split them later.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-11-2007, 03:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
NathanUK
I have seen pics of your car. very nice work, now that I see the Mod list. I know a little about shortening the final ratio on the G50. but does that makes you loose top speed. or is their somthing done to the 4 gear to make up for the diffrence?
BOOST =
Old 06-11-2007, 03:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
A fellow Pelacanite
NathanUK's Avatar
This is such a learning curve.
The "shortened" refers to the physical length of the transmission being actually shortened.
A different clutch plate is used (thinner), the bellhousing is shortened & finally the big one, the input shaft is shortened and welded onto to build it up and then it is machined.
This is how the later G50 transmission replaces the 930 transmission & is fitted into an earlier car.
However, I do suspect that my 5th gear has been lowered than stock. I can imagine it would be great on a track. Shifting from 4th to 5th hardly reduces the RPM's at 70mph.
Old 06-12-2007, 11:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
Driver
Noah930's Avatar
Here's a thread on what it takes to upgrade from 4-spd to 5-spd. Again, most people don't feel it's worth the effort and expense. Just get the 5-speed, if you really care that much.\
edit: Don't know why the direct link isn't working. So just click on the red "Turbo" on the left, and then "911 Turbo." There's a thread on conversions.
1987 Venetian Blue (really looks like grey) 930 Coupe
Old 06-12-2007, 05:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
A fellow Pelacanite
NathanUK's Avatar
http://forums.rennlist.com/rennforums/showthread.php?t=358424
Old 06-13-2007, 02:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
So how do you identify a G50/50 or G50/52. are they marked with these #s. Also what is the top speed ona 4 speed compared to a 5 speed?
BOOST =
Old 06-13-2007, 03:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
A fellow Pelacanite
NathanUK's Avatar
The trannys are marked with a number. Also marked with a 12 to indicate LSD IIRC.
There are various 5 speed boxes, each one may have different ratios.
Approx 160 to 180 mph depending on which tranny. Hopefully someone knows exactly which is which.
The plain G50's and the 915's will be the 160mph boxes.
The 930's 180mph ???
The G50/50's 180mph ???
Old 06-13-2007, 03:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
e p slick's Avatar
Sorry
Sorry but we have taken a vote and decided you will not be allowed to buy a Porsche. There is no appeal and our minds will not be changed. Sorry.
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 06-13-2007, 07:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
dewolf's Avatar
Re: Sorry
LMAO
Old 06-13-2007, 08:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Re: Re: Sorry
Originally posted by dewolf
LMAO
What are you? a 2 year?
BOOST =
Old 06-13-2007, 11:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
Re: Sorry
you too slick.
BOOST =
Old 06-13-2007, 11:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Re: Sorry
On the other side their is a lot of nice people on here that been very helpful answering my questions, emailing me useful links, information and articles about the things I need to know. You two should be ashamed of you silliness and quite it.
BOOST =
Old 06-13-2007, 11:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
dewolf's Avatar
Re: Re: Re: Sorry
yep, a 2 year 930 owner. that is I've owned it for 2 years.
Old 06-14-2007, 12:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
dewolf's Avatar
Re: Re: Sorry
What YOU should be researching without coming on here sounding like a moron. If you're going to buy a car, any car that's expensive you do a internet search and learn what you can. Then go onto forums and ask the right questions.
I find it hard to believe that you've done all that work to your Saab and you know nothing about Porsche. I'm not saying I know everything but I try to find related articles before asking uninformed questions.
Find a car you like, drive it ( have you driven one yet), if you like it, have it inspected. If it checks out, then buy it. Don't ask 1 billion questions that aren't even relevant to the car you DON'T own.
It's easy to say " I want a Porsche turbo" and it's even easier to find informative articles across the internet. Like I said, go drive some. Porsche's aren't for everybody, and that's something only you will find out for yourself. And remember that if you want a really fast Porsche turbo you better have very deep pockets.
"Sorry but we have taken a vote and decided you will not be allowed to buy a Porsche. There is no appeal and our minds will not be changed. Sorry."
And yes, I find this statement very funny
Old 06-14-2007, 01:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
If my questions are hurting you so bad then just do not come back hear, I find that you are the one sounding like a moran when you keep coming back to a thread that you are not supporting. And why just to talk garabage.
Go away, you and your body. One day your jaws will be droping over the Porsche I will build and you will be ashamed of your rudeness and chieldish acts. Unbeleivable. again if you are so annouyed . then unsubscribe. It's Plain and simple. and please..... I do not need your generous advise... it's too late for that... keep it for your self. their no need to pretend to be advising me after you've been so rude . Just go away and enjoy your life.
BOOST =
Old 06-14-2007, 03:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
dewolf's Avatar
Still haven't driven one yet have you? It would seem everybody here is doing all the research for you, would you like us to find a car for you too?
you wrote;
"this nice too but the price is too hot to touch."
http://cgi.ebay.com/ebaymotors/1987...tem180128036116
This is too much and now your going to build a fire breathing beast, lol
you also wrote;
"I know a little about shortening the final ratio on the G50. but does that makes you loose top speed."
Once again you've done all that work to your Saab and you don't understand that lowering (shortening) the ratio will lower the top end!! WT
Oh and by the way, when I was looking for my 930 I did my own research then came here to learn more. I have a 930 Turbo and you have a ??
In Heaven… the mechanics are German, the chefs are French, the police are British, the lovers are Italian and everything is organized by the Swiss.
In Hell…the mechanics are French, the police are German, the chefs are British, the lovers are Swiss and everything is organized by the Italians.
Old 06-14-2007, 03:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
dewolf's Avatar
My Porsche's for your viewing pleasure
Old 06-14-2007, 05:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
