Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
kellcats521's Avatar
Cam oil restrictors
Anyone have any opinions on using these in a turbo motor? Could they result in too much flow to the turbo, and subsequent issues with the turbo and/or scavage system???
Thanks!!
Pat K
87 930
Old 06-11-2007, 11:24 AM
ael911's Avatar
I am not a turbo expert, but Henry Schmidt uses them on every single engine he builds. There is a thread in the engine rebuild forum with some good info.
'75 911S Silver Anniversary #164(Formerly JTO's)
Rebuilt 2.7 with full ARP, 9:1 CR.
SSI, GHL, ER polybronze bushings, finned oil lines.
Lowered and corner balanced. CIS retired, now PMOs!
'65 912 slate gray sunroof (driving project)
Old 06-12-2007, 09:00 AM
GO DAWG GO's Avatar
AEL911,
Maybe you and I could install them on my 930 and if the motor throws the chains and the cams go south...we can rebuild it. I would like to see a bump in oil pressure. Try out your new floor jack?
Bob
1 bad 930
Old 06-12-2007, 10:12 AM
ael911's Avatar
Sounds good to me Bob, but you can't blame me or the restrictors if your chain goes. I have nothing to do with your failing tensioners...
Old 06-12-2007, 10:34 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
