Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
935TURBO's Avatar
Heads and base cylinders gaskets....who can help....?
Hi Turbomen......very urgent....
....I'm looking for gaskets as follow....who can help me....?
For the heads (962 IMSA heads)....gaskets "ring" steel diameter 103 mm int / 107,4 mm ext, deep gasket basement 10/10e
Base cylinders (MAHLE 3.5 l / 7,5/1)...flat gaskets coper diameter 105 mm int / thickness 5/10e.....
Thanks a lot...
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 06-12-2007, 01:41 PM
onboost's Avatar
Question..
What makes these 962 heads? They have 930 part# with 1985 production cast? Just curious.
As for the .. "gaskets "ring" steel diameter 103 mm int / 107,4 mm ext, deep gasket basement 10/10e"
I think what you're looking for is a flame ring, or nirosist ring. This is something the machine shop will need to make for you..the cylinder edge will need the same groove for the head to mate.
RGruppe #180
So many cars..so little time!!
Old 06-12-2007, 02:18 PM
"Question..
What makes these 962 heads? They have 930 part# with 1985 production cast? Just curious."
Paul Weir was selling 962 heads here and on ebay a bit back.
FS Set of 6 factory 962 racing heads
Maxx
86 Ruf'd and rebuilt (sold)
Old 06-12-2007, 02:28 PM
onboost's Avatar
So these are those heads? Don't appear to be.
RGruppe #180
Old 06-12-2007, 02:36 PM
juan ruiz's Avatar
Did you try Todd at Protomotive ? Maybe Tim can also help you
10.76@139-1/4 mile
0-1 mile 193MPH
Old 06-12-2007, 03:28 PM
No such claim made. Only providing a reference to what 962 heads look like, as advertised by PW. One of his pictured shows a part number with "962....".
Maxx
Old 06-12-2007, 08:16 PM
WydRyd's Avatar
I'd contact Todd @ Protomotive as they use Nerosist rings extensively in their big HP builds. They typically use an aluminium sealing/flame ring which has the same expansion characteristics as the OEM cylinders/heads, which is very important.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 06-12-2007, 09:15 PM
"I wuz the liquor..."
sand_man's Avatar
I'd also try Performance Developments, Neil Harvey:
http://performancedevelopments.com/products_engine_cylinderhead.php
Neil has an amazing range of skills and knowledge regarding Porsche Turbo engines...specifically the racing engines.
-jeff
Old 06-13-2007, 11:05 AM
935TURBO's Avatar
Originally posted by im4duke
"Question..
Thank you all for those first answers.....
Yes...!.....I bought those heads from PAUL WEIR...2 years ago....they have been machined a little bit (gasket basement )....and polished (exhaust, combustion chamber, valves in and out)..
Cylinders are brand new...but Mahle is not delivering gaskets...!!!
Here are the problems.....
Old 06-13-2007, 12:04 PM
WydRyd's Avatar
You need custom/aftermarket sealing rings made up for those heads. You'll need to get the grooves measured and have appropriately sized rings made up. I doubt they'd be an off-the-shelf product
Merv
'89 911 Turbo Cab
Old 06-13-2007, 04:34 PM
You could contact Flatout Group http://www.flatoutgroup.com and speak to someone at their Gaskets division. They make all my custom base shims and head gaskets and specialize in small run and are very reasonably priced.
Charles Navarro, LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
'99 Boxster powered by Flat 6 Innovations; '10 Cayman S (DFI testbed)
Old 06-13-2007, 06:27 PM
Banned
I will go to Neil Harvey, at www.Performancedevelopments.com, he is the man.
Old 06-14-2007, 06:23 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
