Safe Turbo Upgrade?
I've searched and came up with a lot of different info. I have a 86 930 with just a GHL exhaust (muffler) on it and I'm thinking of upgrading the stock turbo. Which way do I go? I'm not looking to get crazy here. If all possible I would like to just change the turbo and not have to modify anything to install it.
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 06-12-2007, 04:38 PM
Crotchety Old Bastard
RarlyL8's Avatar
I honestly don't think there is a "stock replacement" turbo on the market. The K27 family are advertised as "stock replacement" but let me tell you they are not. The alignment is wrong and the bracket will no longer fit without modification.
Lots of folks will chime in with there favorite turbo. All require some tweeking to install. Up side is it is well worth the effort.
Old 06-12-2007, 05:01 PM
Me like track days
Craig 930 RS's Avatar
Chime!
Perhaps a K27 7200 Hyflow Turbocharger from:
http://www.ultimatemotorwerks.com/products.html#930
Run it at stock boost, no track use and I suspect you will be fine.
Just check that all fuel and ignition everything is working correctly -
A HUGE improvement over stock - but Brian is correct, tinkering with the mounting will be required.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-12-2007, 06:33 PM
WydRyd's Avatar
+1 for the K27-7200-S or K27-HFS for a more "drop in" replacement compared to the Garrett or Turbonetics alternatives.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 06-12-2007, 09:18 PM
RarlyL8's Avatar
I received a few e-mails asking me to explain why the K27 isn't a drop in.
My verbiage may have been a little strong. They may not simply "bolt on" but at the same time the mods needed to make them fit correctly are not that big of a deal.
The point I would like to make is that you should not expect to simply un-bolt your existing 3DLZ and bolt-up a K27 in an hours time. The alignment of the turbo outlet to the intercooler up-pipe is a little off requiring an adapter or you can cut the up-pipe and add a silicon hose. The turbo bracket will need the holes elongated or cut and re-welded.
Old 06-13-2007, 05:09 AM
kellcats521's Avatar
I will have the machined K-27 outlet adapter (~$100 new) available in a few days if needed. I'm swapping to a longneck intercooler and won't need the adapter anymore.
Pat K
87 930
Old 06-13-2007, 06:54 AM
thechiller's Avatar
Originally Posted by Craig 930 RS View Post
Chime!
Whats advantage of this turbo against the stock yurbo on a 1986 930, does any one have performance curves?
Kjell
911 Project
Old 11-09-2007, 01:08 PM
Me like track days
Earlier boost, much better response -
Old 11-09-2007, 01:15 PM
Smart quod bastardus
fredmeister's Avatar
I just got done installing a k-27S with GSF headers on my 79 930. Used to have the stock 3LDZ and US exhaust.
Night and day difference. The boost comes in very early and is more linear. I am making boost around 2200-2400rpm (meaning coming towards the positive side of the bosst gage) and the boost is all in alot faster.
It has transformed the car. Now it is alot easier to modulate, but the kick of the old turbo at high revs is more subdued.....the only downside, as I used to like that feeling though it is not as powerful as the new set-up.
It was not an easy drop in install.
I had posted a long description of what I went thru if you search the forum. I do not think Rarlyl8 wording was too strong.......you should be aware of whats involved because the sellers of these kits will not tell you.
Worht the trouble definitely.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 11-09-2007, 01:16 PM
thechiller's Avatar
Hello
I found this on e-bay:
http://cgi.ebay.com/ebaymotors/New-K27-7200-Turbo-for-930-or-965-replace-your-KKK-3LDZ_W0QQcmdZViewItemQQcategoryZ33742QQihZ015QQite mZ250185686652QQrdZ1QQsspagenameZWDVW
Is this the same turbo? any good?
Kjell R
911 Project
Old 11-09-2007, 01:28 PM
Originally Posted by thechiller View Post
Hello
Kjell R
That's Kevin (who also posts on this board). He manufactures the hybrid turbos that Imagine Auto sell.
That is, however, a K27-7200, as fitted stock to a 965. Still an upgrade from a 3DLZ, but not the best you can possibly do with a K27.
The K27-7200, K27-7006, K27/S, K27/HF (no longer made), K27/HFS & K27/HF2 are all different turbos, with different characteristics.
See: http://www.imagineauto.com/turbos.htm
'77 S with '78 930 power and a few other things.
Old 11-09-2007, 02:20 PM
Kjell
I've never seen compressor maps for the K27 family, although they exist for the GT series.
Here's a mild 1978 RoW 930, 8:1, SC cams, stock headers, stock wastegate/spring, stock 3DLZ, stock airbox & filter, stock intercooler, open pipe.
Here's the same motor after the spun rod bearing. 8:1, SC cams, GHL headers, stock wastegate/spring, K27/HF, EVO Motorsports intake, Kokeln intercooler, factory muffler.
It makes .5 bar @ 2500 RPM on the rollers. Both setups with open wastegate dump pipes.
Note that the K27/HF setup makes more power at the rear wheels than the factory 3DLZ setup did at the crank. And comparing the power curves should clarify a few things, too..
Like kellcats says, you'd put money on the factory setup being more powerful, because it just feels insanely brutal. But the more modern setup is much, much faster - and progressive, civilized, predictable and controllable. You have to pay attention, because you could be going much faster than you realise.
Old 11-09-2007, 02:38 PM
thechiller's Avatar
Spuggy
Are you using CIS on your car?
Kjell R
911 Project
Old 11-09-2007, 10:56 PM
Kjell R
Yessir. Brian Leaske adjustable WUR fitted during the rebuild, otherwise stock 1978 RoW CIS.
Had the RPM solenoid fitted and ready to go (not plumbed), but there was no need to use it.
Old 11-10-2007, 12:44 AM
hipdoc's Avatar
turbo upgrade
I too put a K27-7200 in my 79' 930 and it isn't just a "drop in" mod. The adapter to the intercooler hits the air intake tube so I had to heat the tube and slightly bend it. The sheet metal needs to be trimmed and the oil sump line needs to have two different threads connector (one to the sump and one to the hard line that goes to the pump). I also put a MSD, put Clewett's ignition wires, put a 1.0 bar string, and GHL exhaust while I was there. Runs great now and lots of boost and worth the time.
Old 11-10-2007, 09:17 AM
