Send a message via AIM to FlashGordon
No start condition
I have a no start condition. It began as an intermitent problem, but now nothing. I do not hear the fuel pump prime. I just get a click when turning the ignition all the way to the right. Battery is fully charged. I'm thinking DME relay, possibly? I don't think it could be a fuse because of the intermitent aspect of it. Any other ideas on what it might be or where to look?
How do I replace the DME relay and where is it located (if it sounds like I'm on the right track)?
Thanks, Rob Gordon
Old 06-13-2007, 12:22 PM
You don't have a DME relay if you own a 930.
I actually have the same problem... happened again today. After feeling around behind the ignition swich the car started up. There is a large socket plug behind the dash just beyond the ignition that seemed to maybe do the trick for me... tough to say though. It also seems to only happen if I park the car on a slight incline. Although that could simply be a coincidence.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 06-13-2007, 12:43 PM
Alright, so much for my research...
Old 06-13-2007, 01:22 PM
The DME relays are common problem areas for the non-turbo cars... so your research was technically probably correct
Rob Montgomery
Old 06-13-2007, 01:23 PM
Anyone?
Old 06-15-2007, 04:06 PM
mark '87 930's Avatar
Did you check all your grounds? Wires going to your starter? If your battery is good, and you get a click, there is a loose connection somewhere or something that needs cleaning up.
The ignition switch is certainly something to fiddle with as well, I would look at and inspect ground straps and battery terminals, and starter wiring as well. What car do you have? Have you tried a boost, if so, does that work?
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 06-15-2007, 05:38 PM
A fellow Pelacanite
NathanUK's Avatar
Have you tried hitting your starter with a hammer? Sounds as though it may need to be replaced.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-16-2007, 12:13 AM
Yes, tomorrow I'm going to attack it with a ball-peen hammer...
Old 06-16-2007, 03:41 AM
A fellow Pelacanite
NathanUK's Avatar
It has always helped me in locating a faulty starter in the past. Never had to do it on a 911 yet though thankgoodness.
Old 06-16-2007, 01:49 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
possible ignition switch
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 06-18-2007, 04:10 PM
Thank you for the advice, guys. I'll get on it this weekend and let you know how I made out.
Old 06-20-2007, 06:57 AM
